-   -   Door lock not working , question... (http://forums.pelicanparts.com/porsche-911-technical-forum/116691-door-lock-not-working-question.html)
Oracle 06-27-2003 10:32 PM
This door lock is auto-unlock ???
Hi,
The driver side door handle is not really working as it should..
I locked the door using the key then if I pull 5-10 times the door handle, the lock will go out of it's locked position and the door will actually open!!
Anyone one knows what can be wrong ?
Thank a lot!
-J :confused:
dean 06-29-2003 04:14 PM
Sounds like something might be loose in there. Take it apart and have a look
Rod911 06-30-2003 04:41 AM
Hi,
This happend to me a little while ago. I had leaking door rubbers which caused water to go down into the door. The whole lock mechanism was rusted which caused it to stop working. Ended up replacing the entire lock (had the shop do it...major $$$$).
Might help to get the lock out and clean it very well.
