Help finding wiper seals Billstein struts
'78 SC
What are people using to replace worn rubber seals in Billstein struts? I haven't been able to source the part. I purchased Billstein B6 inserts, but need to replace the rubber seals that sit below the metal caps, they're hard as rock. Talked with our hosts, their suggestion is to buy a pair of complete front struts at $1,154.00 each to get this $5 gasket. The metal cap is fine but I need new rubber. This seal has a spring collar. http://forums.pelicanparts.com/uploa...1726175115.jpg http://forums.pelicanparts.com/uploa...1726174794.jpg http://forums.pelicanparts.com/uploa...1726174866.jpg |
For 40mm struts this shows as a spare you can order from Bilstein for $12. Summit racing lists it for $18.
Genuine Bilstein 40mm insert seal. E4-B36-800A |
Wow that was easy, thank you. I'm gonna have to learn to search better
| All times are GMT -8. The time now is 12:32 AM. |
