'73 911 T Targa
Seafoam soak
I’ve used Seafoam in small engines and occasionally in a boat motor by shutting off the gas supply, then filling the float bowls with Seafoam. Then, I let the engine run briefly on pure Seafoam so that the Seafoam gets in to all the passages. Smoke is the sign that it’s in.
After that, I let it sit for a day, then connect the gas supply back up then take the engine out for an Italian tune-up. It’s worked wonders in these motors, but for some reason I’m a bit more fearful of trying it in the precious 911 engine. Are there any opinions to be had on this? Last edited by Quickstep192; 09-13-2024 at 12:17 PM.. |
It can thin out your motor oil so . . as long as you change your oil after the seafoam flush.
'73 911 T Targa
I think he means you can add it to your oil as well as pull it in via the vacuum lines. But you need to change the oil shortly after.
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
