Will -
Didn't measure the exact angle as it sits but I figure about 4 Deg slanted towards center. Car has Weltmeister spacers. Alignment specs are as follows - camber L -.8 R-.65 deg caster L 6.46 R 6.64 deg Toe L 2.7mm R 2.7mm Rear camber L -1.62 R-1.5 deg Toe L 1.7 mm R 1.7mm Car drives beautifully, tracks well and tire wear is good. 12K so far on these settings, not a single problem. |
| All times are GMT -8. The time now is 12:46 PM. |
