-   -   Going from Petronix back to points - capacitor? (http://forums.pelicanparts.com/porsche-911-technical-forum/1167147-going-petronix-back-points-capacitor.html)
Quickstep192 09-17-2024 01:33 PM
I’m switching back to points on my ‘73 Targa with Bosch 0231.169.XXX distributor and CDI.
I can’t remember what all I removed when I installed the Pertronix.
Would there have been a capacitor on the distributor?
Thanks for any help
rwest 09-17-2024 01:51 PM
No, the points act more like an on off switch, so the tiny round silver tube on old distributors is not used.
HarryD 09-17-2024 02:02 PM
You need a capacitor with points if your do not have a CDI to help reduce the chance you will rapidly burn your points. Pertronix does not require a capacitor.
rwest 09-17-2024 02:38 PM
Originally Posted by HarryD (Post 12322928)
You need a capacitor with points to help reduce the chance you will rapidly burn your points. Pertronix does not require a capacitor.
Harry,
He has a CDI, does it still need a capacitor? My car didn’t have one.
HarryD 09-17-2024 02:53 PM
I stand corrected.
mysocal911 09-17-2024 06:17 PM
That's a small part of the reason. The real reason is that without a capacitor, the rise time of the coil primary voltage is too short when the points open,
resulting in a poor spark at the secondary winding to the distributor.
HarryD 09-17-2024 06:49 PM
We are really saying the same thing as the consequence of not getting the energy to the coil, is an arc across the points.
The capacitor(condenser) absorbs the excess energy then releases this energy to the coil.
Quickstep192 09-17-2024 07:26 PM
It doesn’t take a lot, but I’m confused.
No capacitor as long as I have CDI, correct?
HarryD 09-17-2024 07:49 PM
yep
mysocal911 09-17-2024 07:52 PM
Technically, it's controls (defines) the dv/dt (rate of change of the primary voltage) based on the primary inductance.
mysocal911 09-17-2024 07:54 PM
It doesn't matter!
HarryD 09-17-2024 07:59 PM
Errrr. Ummmm. Let’s not bring calculus into this!
PeteKz 09-18-2024 03:49 PM
Re the purpose of the condenser (capacitor): it's a moot argument. Back when Charles Kettering first invented the "Kettering ignition system" he found that the points were burning too quickly, due to the arcing across the gap as the points opened. Knowing a few things about electricity, he added a capacitor, sized to absorb the current across the points until they opened far enough so that the spark would no longer jump and burn the points. dv/dt had nothing to do with this innovation. It was a practical adaptation to stop points from burning.
It also serendipitoulsy turned out that adding the capacitor created a resonant RCL circuit that increased the peak voltage of the coil. Win-win. Then comes the post hoc explanation of dv/dt.
Anyway, if you have the CDI box, the points don't carry significant current, so you don't need the capacitor. They only signal the CDI box.
mysocal911 09-18-2024 08:02 PM
You obviously don't understand the simple electronics circuit analysis of what happens when power is removed, e.g. points open,
from an inductor (ignition coil) without a capacitor or a voltage limiting device. The change in voltage versus time (dv/dt) becomes basically uncontrolled
and very high, potentially damaging the coil. That's the key purpose of the capacitor in the distributor of a simple points ignition system.
And as a result of the controlled dv/dt, it also reduces the burning of the points (arcing).
It's that simple!
PeteKz 09-19-2024 01:20 AM
You've got the actual development backwards.
yelcab1 09-19-2024 07:10 AM
@quickstep192, why are you going back to points away from Pertronix? Is it originality or something else?
Quickstep192 09-19-2024 03:02 PM
Mostly just tinkering and trying to go back to an original base point. I’m chasing a mid-RPM miss.
I originally put in the Pertronix before I learned that the points in a CDI system are just a trigger.
I’ll see how it does with points and then maybe switch back.
