Headlight trim screw tab repair
Headlight trim retainer screw tab repair on 72 porsche. THE TAB IN THE FENDER WELL BEHIND THE HEADLIGHT TRIM IS RUSTED AND THE TRIM SCREW NO LONGER WORKS'
Old 09-22-2024, 09:53 AM
Been here a while
Lots of threads on this. The right way is weld a new nut in place. Some guys use a speed clip after grinding off the old nut. Or jb weld a new nut in place.
What do you mean it’s busted? How about snapping a photo.
Can you drill and retap the existing nut?
looking for 1972 911t motor XR584, S/N 6121622
Old 09-22-2024, 11:59 AM
skinnerd's Avatar
I've got a similar problem and will be using a machine thread speed clip/nut like below.
I'll be able to use the stock threaded screw.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 09-22-2024, 10:35 PM
I soft-soldered a new nut onto the back of the tab on my car about 15 years ago and it’s still working well. A very simple repair
Old 09-22-2024, 10:53 PM
Bill Douglas's Avatar
I mig welded a ew nut in place. Just make sure your angles are correct.
Old 09-23-2024, 01:47 AM
I used a speed clip on mine like the one pictured by Doug above. Worked very well.
Old 09-23-2024, 08:21 AM
