Valve cover gasket glue
After fighting to get my valve covers off, I was wondering, are they supposed to be glued? What do you use? Will they seal well enough without a sealant? I still have original valve covers on my 2.4 based engine, does that make a difference? Thanks, Michael
Old 07-06-2003, 11:37 AM
As far as I know, they're definitely not supposed to be installed with a sealant. (I use the thick red silicone Real Gaskets, which certainly aren't supposed to be sealed, but I don't think the conventional ones should be either.) The secret to valve-cover sealing seems to be 1/starting out with true, flat valve covers and dressing them to be true if they aren't, and 2/careful, systematic, relatively light torquing to the proper values of the nuts, to avoid warping the fairly flexible valve covers.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 07-06-2003, 01:37 PM
Thanks, Stephan. These were glued with a kind of brown glue. They were a little hard to remove. I have a set of gaskets from the dealer not the silicone ones. I'll get a set of them next time. These are green and grey. I'll check my covers with a straight edge. Thanks, again. Michael
Old 07-06-2003, 02:16 PM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Michael,
a good upgrade for your car is to get the turbo valve covers. I got some and no more leaks.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 07-06-2003, 02:36 PM
Senior Member
Superman's Avatar
Be sure to remove all the old sealant. Sealant should not be used. Find someone with a REALLY BIG belt sander, one of those table-sized things, and use it to gently ensure the sealing surface is straight.
Mocha 1978 911SC. "Coco"
Old 07-06-2003, 10:28 PM
smarjoram's Avatar
I had that brown stuff too - made it really hard to get the covers off. Cleaned it all off and installed the new ones without and there are no leaks at all. One of the previous owners installed turbo covers at some point.
'81 SC
stefanmarjoram.com
sketch blog
flickr
Old 07-07-2003, 12:34 AM
