just did a little noodling
it looks like a 1" move at the end of the sway bar is .992deg on A arm swing w/ the new style front underbody bars so anyone know how much further out on the A-arm the ball joint is? |
so 275mm from the A-arm axis to the balljoint center? |
Re: the two sides acting in the swaybar … while true, the force applied to the swaybar by the unloaded side of the car is small because it’s basically limited to the unsprung weight of the suspension/wheel assembly acting in the downward direction. The loaded side has the force of the weight transfer acting in the upward direction. I don’t have data to quote, but this force is substantial, or we’d have no need for swaybars in the first place.
As for the force delivered by the swaybar in resisting upward suspension movement on the loaded side, it will be the full force of the bar. I’m not seeing why it would be half. Or maybe I misunderstood the assertion. |
as to the geometry, I've resigned myself to get under there tomorrow and do some measuring, it looks as if the sway effective point is ~3/4 of the way out from the pivot if that were so, then 400#/in is an effective 300 lb/in we''ll see when I get the #s |
I'm not tracking the math on the angle, maybe I'm misunderstanding which angle you're talking about; 0.992 degrees at the A-Arm center of rotation is only 4.8mm at the ball-joint. Quote:
The correct calculation is the motion ratio squared, so it's not gonna see 300 lbs of wheel rate. If the length of the lower control arm from the ball joint to the center of the torsion bar tube is 11.5" and the centerline of the hoop for the sway bar is 4.5 inches from the ball joint the calculation should look like: (11.5 - 4.5) / (11.5) = 0.6087. square that and you get 0.3705. Measured rate of bar = 400 lbs/in x 0.3705 = 148 lbs/in wheel rate. |
W?O a lift available it's been impossible to get good measurements
anyone have some A-arms laying around that can tell me what X is(it should be ~5-6" I believe that the 275mm(10.826771in) is correct http://forums.pelicanparts.com/uploa...1727363815.jpg |
the sway is .46 of the pivot to ball joint distance- -4.9" where did the 11.5 come from? dis you measure that? the other # I have for that is ~10.83" why squared? anyhoo I think that we are getting close here's what I have so far in beta 4 different t-bar setups for the same car otherwise, all w/ 20/18 underbody sways http://forums.pelicanparts.com/uploa...1727381425.jpg http://forums.pelicanparts.com/uploa...1727381425.jpg |
Yes, I crawled on my belly like a reptile and measured them, but I was assuming the hoop attachment for the underbody bar and not the through the body bar. (Actually, the car was up in the air a little bit)
The motion ratio is squared in the calculation to get the correct wheel rate. Once for the force and once more for the distance. Also, the calculations change for the metallurgy, so keep that in mind. I have notes somewhere for the two most common materials and tempers used. Or bolt the bar to a bench or table and put a bathroom scale under one end and a dial indicator under the other side, then apply force with a big pipe wrench. |
dug out my Puhn and that confirms the square aspect my confusion was that the motion ratio for the torsion bar isn't the same as the motion ratio for the sway bar at either end. I'll use your #s for now and check down the road i do have the bench measures for some 993 sways, but not 911 not concerned w/ metallurgy as I'm mostly concerned w/ the factory bars thanks for your help!! |
now for the rear
as best as I can measure he OC distance from the t-bar pivot to the axle is ~19" and the OC distance from the t-bar pivot to the sway bar mount is ~11" can anyone confirm or provide a better measure? |
| All times are GMT -8. The time now is 05:25 AM. |
