Oil level gauge pegged!
My oil level gauge once thermostat is open the gauge bounces and goes to max until it cools down. The wiring isn’t damaged and the dipstick is half way. Not sure where to look next. Is it a short in the ground? Anyone else have the same problem
Old 09-07-2024, 04:23 PM
Been here a while
I suspect you have a dead spot on the sender unit in the tank.
looking for 1972 911t motor XR584, S/N 6121622
Old 09-07-2024, 05:17 PM
In the car, it can be changed. A little tricky to get the float in.
Old 09-07-2024, 05:36 PM
That's fond- just deglaze
Hi Flat sixx- Here's my story (with video). The use of a Porsche factory-branded sender solved my issue.
https://forums.pelicanparts.com/porsche-911-technical-forum/1142237-question-wonky-oil-level-gauge-video.html
Hope this helps!
Missed Approach
Petra- 1986 Coupe
Old 09-07-2024, 08:22 PM
New-ish 911SC Targa Owner
pampadori's Avatar
I replaced my float sender with a URO part about 3 years ago. Has been working as it should ever since.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 09-09-2024, 09:33 AM
Thanks for all the responses. Gonna order a sender unit and check if there’s a flat spot in the old. Has anyone bought the dansk unit it’s 70 cheaper then the OEM
Old 09-22-2024, 06:22 AM
