Checking Freon Level
I suspected my 88 was low on R12 so decided to add some but I have a question about the site glass. Before I added anything it appeared to be clear w/ ac on and running at 2k rpms and the small ball stayed at the bottom. I hooked up the freon and had my gf keep it at 2k rpms. The freon can got VERY cold and the a/c is now running about 15 degrees cooler at the vent. (Previously saw 70 w/ ambient temp low 90's, now seeing upper 50s at vent, same amb. temp) The site glass looks exactly the same...totally clear and little bead/ball at bottom. Is it possibly still low? About how long should a system take to take in a can of R12? I ran it about 5 minutes and the bottom 2" of the freon can was ICE cold with frozen condensation on outside.
Thanks, |
How big was the can of R12? I believe your car holds about 40oz total.
...Bruce |
It was a 12 oz can but the system was far from being empty. I'm just curious as to what I should have seen on the site glass and if maybe I should have kept the can on the car longer. It's sealed up so I can add more freon if that's what's needed.
As far as I know you should see the ball floating in the middle of the sight glass. You can also get a pressure gauge and check the system pressure at the compressor to get a better idea of how much freon you have.
...Bruce |
I've never trusted the "sight glass" on any car, much better to check pressures or, even better yet, monitor temp. at the vent; add coolant unitil you see temperatures in the mid to high 40's at the center vent with the fan at 1/2 speed, that's probably as good as you'll ever get with the stock system. BTW, if the system is close to fully charged it can take 10-15 minutes (or more) to empty a can of R12, then you should let the engine run (or better yet drive it) for 20-30 minutes to let the system equalize. Then check the temp. at the vent. BTW, where did you get a can of R12? I'm still hoarding my last one.
One last thing, if you over-fill the system you'll start losing cooling capacity. Good luck, Jerry M '78 SC |
| All times are GMT -8. The time now is 12:56 PM. |
