proporsche's Avatar
Strainer plate new type of drain plug
Anybody has used this kinda drain plug which comes nowadays wit the strainer plate?
I wonder if i should trust it since it does not have the seal just the cone shape how it was manufactured.?.I know there is word for it...;-)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 09-30-2024, 12:37 PM
'82 SC TL
canamfan's Avatar
How does it bottom out for torque spec? I see no shoulder
76'S 1st Porsche white/can/can early rebuild (boo)
'84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1)
'87 Carrera cpe white/blue short flirt
'89 Anniv. sil/linen very pretty miss her
'88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Old 09-30-2024, 12:46 PM
proporsche's Avatar
It is cone shape..you can make it really tight but i wonder if it could trust it for an oil leak?
Ivan
Old 09-30-2024, 12:51 PM
Behind the Sun
If it's aluminum it will deform and seal until you need to buy another plug
Old 09-30-2024, 12:56 PM
proporsche's Avatar
it is steel made...
Just finishing 930 engine and 1975 i could put it on but i hate to drain the oil if it would be leaking...
Old 09-30-2024, 01:11 PM
pete3799's Avatar
I assume it must be tapered pipe thread in which case it should seal ok....does the other plug thread into it?
Pete
79 911SC RoW
Old 09-30-2024, 02:47 PM
Cory M's Avatar
It most likely uses a tapered pipe thread. Could potentially wear out over time. I'd rather have one with a replaceable seal. Tarett sell some nice machined aluminum ones that have a normal sealing plug.
Old 09-30-2024, 03:02 PM
It's a 914 ...
stownsen914's Avatar
A tapered plug + some curil T or similar ought to seal it in case the taper alone doesn’t.
Old 09-30-2024, 03:26 PM
proporsche's Avatar
yes the strainer plate is original and it takes regular drain plug.
I guess i will test the new plug on the 75 engine since it will be in the same town (my budd`s car)
And use original on the 930 with seal-this goes later Budweis where the original Budweiser is brewed;-)
thanx guys
Ivan
Old 10-01-2024, 01:21 AM
PCA Member since 1988
Ivan, make sure the new plug is the same thread pitch as the original plug. Pipe thread usually is a different pitch than normal thread!
Otherwise, I would follow plumbing practice for pipe threads and wrap the plug with teflon plumbing tape, then install it.
If you are using this new plug as a way to reduce the amount of plug hanging down below the engine, I have a magnetic drain plug that has a flat shoulder with an Allen socket in it. It was on the engine when I got it. But it is normal thread like the original plug. To put it in anatomic terms, it has an "innie" instead of an "outie."
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-01-2024, 04:04 PM
proporsche's Avatar
I have all kinds of plugs also the one you have mentioned.It is just i wonder who comes up with this idea new type of plugs??
I decided i am going to use plugs with the seal on both engines - do not trust this plug;-)))
Ivan
Old 10-02-2024, 01:58 AM
I wouldn't either.
206 637 4071
Old 10-02-2024, 10:03 AM
HarryD's Avatar
IMHO, an oil drain plug is not a critical fastener.
It needs to be snug so it doesn't loosen with time and not leak. Beyond that, no sense wasting my thinking energy.
Personally, I like the crush washer as it gives me a physical indication that the plus is snug enough.
Also, I would NEVER put Teflon tape on one of these as I do not want Teflon particles to be sucked into the pump and get stuck in the oil passages.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-02-2024, 10:10 AM
proporsche's Avatar
Warning!!!
Ok i just got new plugs and guess what boys, be very careful. Whoever makes these plugs now, tried to extend the magnet idiotic way!!!
In one bad was a little triangle piece-i was like wht is this here for. Ok next plugs had it attached.So i took wise-grips and it came of so easy.Can you imagine you do engine rebuilds and hopsss this little scheizer comes off inside you fresh rebuild.So i took them off ...
So be careful...
i called the supplier and gave them kinda hell -the nice Czech way thou;-)
Ivan
Old 10-03-2024, 04:32 AM
Everyone pretty much got it. Tapered thread is commonly called pipe thread but I doubt that would fit any H2O fitting. If you use teflon tape leave the end free of such, don't want a bit floating around in the motor. Personally I would swap out for a flanged fitting. Then the crush washer issue comes up. Consensus seems to be aluminum versus copper for the dielectric issue. Just my 2 cents...
Old 10-03-2024, 07:56 AM
