Troubleshooting no power at Rear Heater Blower Motor
Hello again inmates...
83 SC, manual heat I am not getting power to the connector of my rear heater blower motor when either one of (or both at same time) center heater levers are in the up position. So far I've checked the following... Tested for voltage at the connector with key on (car off and also car running) - No voltage on Yellow wire Tested voltage at the three rear fuses - Top 2 fuses constant 12 volts, bottom 12 volts with key on ![]() Tested the relay (pin 30 to battery, 85 to ground, 86 to power trigger, and 87 produces 12 volts) Visual of the connector at Heater Motor looks good. ![]() Visual of the Lever Switch looks good in up and down position (down, no contact - up, contact) ![]() I'm just not quite sure how to proceed with testing. im not even sure how the lever switch is working exactly.. ive read that the contacts when touching sends ground to relay in the engine compartment (relay?)... its tough to even find where those wires are to see if they are smoked somewhere downstream to engine compartment. any guidance would be greatly appreciated also, yes I am familiar with back dating however I would like to remedy this situation as-is and I'll possibly entertain a backdate project in the future. I'd just like to get things working as designed
1983 911SC - Light Bronze Metallic Last edited by cky3396; 09-27-2024 at 05:36 PM.. |
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Thanks Dpmulvan, relay bench tested and is functional
1983 911SC - Light Bronze Metallic |
alright update from the lab. it is fixed, but im not entirely sure what exactly the issue was.
between inspecting, cleaning contacts, wiggling wires, rotating the base of the relay, plugging and unplugging things... the heater floor levers are now grounding pin 85 on the rear blower relay and im getting a 12.5 volts reading at the blower motor connector. and learned a few things along the way, so thats nice.
