-   -   Carrera 3.2 shroud broken at bolt mount point - how can I fix this? (http://forums.pelicanparts.com/porsche-911-technical-forum/1167617-carrera-3-2-shroud-broken-bolt-mount-point-how-can-i-fix.html)
ErrorMargin 09-28-2024 10:47 PM
The shroud on my 84 Targa is broken at one of the fan housing mount points, see the picture below.
How should I go about repairing this?
I'm not sure a simple fiberglass patch will provide enough strength for this mounting point.
Can I fill in the entire breach point with JB Weld and then drill a new hole through the JB Weld?
I am open to suggestions.
http://forums.pelicanparts.com/uploa...1727588648.jpg
Mike Czech 09-28-2024 11:07 PM
Just an idea, you might take a thin sheet of aluminum and JB weld that under the hole/broken area to function as base, then use some Ptex (it's a plastic rod that's used to fix scratches in ski bases, they sell them in both black and clear colors) to drip-melt into the gap. Then you could drill out the hole. With the Ptex, you should get an even mold throughout, and it should bond well with the shroud plastic - especially if you heat up the shroud plastic a little bit with a heat gun. After you drip-melt the plastic into the gap, you'll have to sand it down flat before you drill your hole. Just an idea. Good luck!
FA-18C 09-29-2024 05:33 AM
JB Weld a washer there.
Dpmulvan 09-29-2024 05:44 AM
Poke two holes stitch it together with wire, then cover it with 3m panel adhesive or other flexible epoxy.
john walker's workshop 09-29-2024 07:31 AM
The plug wire holder covers it. Sort of a non problem. Or use a wider washer under the bolt if no wire holder.
PeteKz 09-29-2024 05:14 PM
^^ This.
ErrorMargin 10-13-2024 05:41 PM
Great suggestion on the wider washer. Problem solved!
This is a 1984 911. Is the Allen bolt correct for this position? Should it be a hex bolt?
http://forums.pelicanparts.com/uploa...1728865865.jpg
ErrorMargin 10-27-2024 05:33 PM
Originally Posted by ErrorMargin (Post 12338565)
...Is the Allen bolt correct for this position? Should it be a hex bolt?
I've looked at several 84s, a hex bolt is correct.
