1972 valve adjustment issue
Doing a valve adjustment on my 1972 911T and it appears someone has replaced one of the valve adjustment nuts with a thicker nut . . not that much of an issue but the nut will not release from the adjustment screw. Can I replace both the adjusting screw and bolt with new while the engine is still in the car? It is an exhaust adjustment so little room to work in the engine compartment. Will the adjusting screw completely unscrew from the rocker or is the end too large to screw thru the rocker arm?
Old 10-02-2024, 01:53 PM
PCA Member since 1988
To remove the adjuster, you need to remove the rocker arm. To do that, you loosen the rocker shaft bolt, and slide the shaft sideways until you can remove the rocker. Installation is reverse.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-02-2024, 02:38 PM
thanks Pete
Old 10-02-2024, 02:41 PM
...and clean out the shaft bore. If there's any dirt in the bore, it will prevent the shaft from sealing in the bore and lead to another one of those annoying oil drips that are hard to find.
Old 10-02-2024, 02:49 PM
Valve Timing……..
Do not forget to set the particular cylinder @ TDC (1-6-2-4-3-5). Make sure the cam is not loaded when you remove/install the rocker shaft assembly.
Tony
Old 10-03-2024, 07:42 PM
thanks - all good info for someone that hasn't done this before.
Old 10-04-2024, 04:50 AM
