1984 Carrera Targa shifter lock pawl
Whilst I was replacing the bushings in the shift linkage I noticed that the lock pawl spring had broken. This is the triangular item on the top plate of the shifter tower that prevents you shifting from 5th to reverse or reverse to 5th
Is there a way to change this spring, I saw nowhere that the missing spring end should locate.
Peter
Old 10-03-2024, 11:52 AM
