-   -   Removing Ignition Switch (http://forums.pelicanparts.com/porsche-911-technical-forum/116794-removing-ignition-switch.html)
North Coast Cab 06-29-2003 07:51 AM
I removed the break-off bolts and rivits and disconnected the electrical portion. I removed the nut on the bottom of the steering column connection and loosened the screw with a small allen wrench. I still can;'t get the swicth out. Does the steering column bolt need to be completely removed? If so, is there a trick?
JG
North Coast Cab 06-29-2003 08:09 AM
I got it. I was pushing the screw in instead of out. Here's what I found.
http://forums.pelicanparts.com/uploa...ion Switch.jpg
I did a search and found an old post where someone used JB Weld to reconnect the broken piece. He said he filed, welded and re-filed to fit.
Does anyone really think it's possible?
JG
