Which Valve Cover Gasket Set?
Our host has several different sets....which Valve Cover Gasket Set to buy?
Damon in STL 1977 widebody with 3.0 1989 BMW M3 M42 1.8 Turbo Race Car |
I get the factory/OEM ones. Work just fine.
Here we go again. Did you try a search yet?
John ..ha ha ha...so funny..BTW..look at the login link..i made an info there
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Get the set with the silicone bead.
Under the radar
The red silicone ones are great. Don't leak and are re-usable.
I second this recommended, just be sure not to over tighten.
_______________________________ 1982 911 SC 240,000mi and counting |
Coram Deo
I'm using the factory ones with the silicon bead and they are working famously. The factory-without didn't, at least on my motor.
The cardboard under the car is 100% clean.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
Control Group
how I found this thread, still no definitive answer though
She was the kindest person I ever met |
I always use for many many years wrightwood gaskets graphite..
Ivan
I had a silicone set on mine for over 20 years without any issues. One got torn on my last valve adjustment so I replaced with Wrightwood. You won't go wrong either way.
Walt 82SC 3.0 81SC 3.6 |
PCA Member since 1988
I've been using the Victor Reinz valve cover gaskets with the silicone beads for the past few years. I reuse them when removing the valve covers for clearance checks. So far, I have reused them several times with no leaks.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
+1 for the VR gaskets. They also come with nuts and washers as a full set.
Ivan
