1972 911 mfi stack air flow
Doing CMA on my 1972 MFI 911T and number one cylinder I get too much air flow and the air bleed screw adjustment has no effect . . and yes I cleaned the air passages. Adjusted the butterfly stop and still no change. How do I get this aligned with the other stacks?
It's been a long time for me. If I remember correctly, similar to carbs, you adjust the low cylinders to match up with the high-flow cylinders.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
My #1 is 10% higher than the others too. Air screws adjusted and cleaned. Personally mine is going into an MFI shop in the spring. They don't like it when you 'fiddle' with it. Possibly it's the bushings. Just acknowledge it if you're selling.
