123ignition ignition distributor (Tune+) - any experiences?
Hi all,
Considering replacing the original Bosch ignition distributor on my Porsche 911 SC from 1978 (Bosch 0 237 306 001), since the distributor needs a rebuild. Rebuild costs are very expensive it seems, at least in Europe, where I live. Then I came across the 123ignition ignition distributor (Tune+) and can see that would be a cheaper replacement than rebuilding the original distributor. BUT before considering it seriously (since I'm normally a sucker for originality), I would like to hear if any of you fellow Pelicans have some good/bad experiences? Any feedback is appreciated. Thx. BR Chris |
I put one in my 1972 MFI and love it. My original distributor was shot and I, as you, saw it as a more cost effective solution. I like the fact its fully electronic, programable, and you can disable the car from theft with the app on your phone. You can also run it with or without a CDI box which makes it better still. Is your car going to run better than with a correctly rebuilt original distributor . . no . . but this is a more maintenance free solution and gives you wide open options regarding ignition curves.
I also have an 123ignition tune in my SC. Pretty satisfied. We had several discussions here about it. Too lazy to summarize it again. Please have a look into the discussions, if you got further questions, let us know here.
https://forums.pelicanparts.com/search.php?do=process&query=123ignition Here's a first glance: https://forums.pelicanparts.com/porsche-911-technical-forum/1155633-dizzy-crane.html#post12318286 Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 10-09-2024 at 07:33 AM.. |
I put a 123 with blue tooth in my 6 cylinder E Type. It's great except for one big problem. The cap they sold with it is junk. I think it was a Beru. The center pin fell out. Lots of folks have had problems with those caps. I found an NOS Bosch cap on Ebay.
1980 911SC Targa 1990 S2 Cabrio (sold) 2004 C4S (sold) 2006 Boxster (sold) |
While I have not used that particular product, being able to adjust the timing curve with respect to rpm and manifold pressure gives you the opportunity to maximize engine power. However, if you do that, I recommend an experienced tuner or you can damage your engine through detonation. When I did my first version of a supercharger install, I used an electromotive HPX system to control timing. Once I went EFI, I played a lot with timing but only because I have two knock sensors installed.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! |
But you can choose replacements by the Beru part no. "VK 102" from Bosch and other vendors. These 6cyl caps are pretty common and widely used as well on BMWs, Mercedes and others. No disadvantage any more. Here's a list I found on the web with complementary types and part no.: Bosch - 1 235 522 051 Bosch - 1 235 522 060 BMW - 12 11 1 351 446 BMW - 12 11 1 353 117 BMW - 12 11 1 354 501 Ford - 0 710 256 Ford - 11 710 256 Ford - 436 826 Ford - 1 144 700 2 Ford - 1 171 026 8 General Motors - 74 060 87 General Motors - VS 11643 General Motors - 79 928 59 General Motors - 79 922 66 Mercedes-Benz - 000 158 16 02 Mercedes-Benz - 000 158 25 02 Porsche - 901 602 936 00 Porsche - 901 602 956 00 Porsche - 901 602 963 00 Porsche - 911 602 215 00 Porsche - 911 602 933 00 Volvo - 241669 Volvo - 76978 Absolutely no warranty for correctness! Quote:
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 10-09-2024 at 07:58 AM.. |
