911 Foam Engine Compartment Sound Pad..DIY?
I like projects! Thoughts on making my own 911 coupe Foam Engine Compartment Sound Pad? Looks easy...have my old one as a template.
Looks good. What did you use?
Ed 1973.5 T |
If you have accurate measurements, a laser cutter, and the right material, it would be a piece of cake. The right material seems to be the hard part.
I used some of this and glued it in with contact cement. Eyeballed it in.
https://www.amazon.com/gp/product/B09BR3PN4V/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
This seems a strange one when you can buy a proper one for the car for so little money
E Sully. I didnt make that. Its the original part...like to copy that
HarryD. the amazon link didnt come up...what did you use? Ian...my birthday is in Sept!...like I said ... I enjoy a project. |
They have this: https://www.amazon.com/Artilife-Neoprene-Perfect-Cosplay-Padding/dp/B08FX3V8Z7/ref=dp_prsubs_sccl_2/134-3904841-5801715?pd_rd_w=KOAda&content-id=amzn1.sym.b3f15950-3c9d-4907-ad05-73533fd419e9&pf_rd_p=b3f15950-3c9d-4907-ad05-73533fd419e9&pf_rd_r=YD3SC7Y635V4AWPQR1CH&pd_rd_wg=iONGj&pd_rd_r=a6f91304-466d-429e-a54b-13e2da06c355&pd_rd_i=B08FX3V8Z7&psc=1
how long?
wow, why 80” long? that just the size sold?.. obviously didn’t need 80”
I found 1/2 X 39 X 78 online at Homedepot site Quote:
It was what they offered and I use the foam for other things as they pop up.
If I had it to do over again I would get a Lizard Skin kit of both their sound deadener and their ceramic under coating. My project would be coat the whole firewall with both first. then I would buy the best quality foam pad I found and just glue that in. Probably the same time spent, a fun project still, and the best outcome. Just my 2 cents, and you got it for free so......take it for what it's worth.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
i found that Porsche dealer sells it fairly cheap. a lot less than most others. $97
| Tags |
| engine compartment , foam , sound pad |
