Replaced H4 headlight bulb, still doesnt light
Clear plastic wire connector has scorch mark on it. How do I fix this?http://forums.pelicanparts.com/uploa...1728853568.jpg
http://forums.pelicanparts.com/uploa...1728853647.jpg |
Both low and high beams don’t work?
Are running normal 55/60W or something higher? |
I got this fixed. It was was just the low beam. The problem was a corroded fuse at the fuse located in the frunk. Each headlight, left, right, high and low has its own fuse. Who knew?
| All times are GMT -8. The time now is 06:25 AM. |
