-   -   where does this wire connect to (http://forums.pelicanparts.com/porsche-911-technical-forum/1168909-where-does-wire-connect.html)
cmcfaul 10-16-2024 09:14 AM
I took the seats out to replace the covers. Everything with the seats works. The Automatic climate control does not work. There is this wire but I cant find where it connects to or what it does. I pulled up the automatic climate control box but there is nothing to connect it to. I dont see anything under the seat either.
The wire looks to run along the seat rail and would be just long enough for the automatic control box. Again, nothing in there to connect to. there is no power to the wire and jumping it (crossing it) does nothing.
Thanks,
Chris
89 Carrera
http://forums.pelicanparts.com/uploa...1729094990.jpg
E Sully 10-16-2024 10:18 AM
Could it be for the seat belt buzzer?
proporsche 10-16-2024 12:16 PM
looks like for your heater control box sensor connector...
Ivan
cmcfaul 10-16-2024 01:03 PM
Ivan
Thanks Ivan, where does it connect, specifically?
Chris.
proporsche 10-16-2024 01:25 PM
well looks like you have semi automatic control unit --remove the 4 screws which hold the body down and inside should be male connector to plug it in..
no 10 here
https://www.eurospares.com/Porsche/911/911_(1984)/PartDiagrams/908-000/HEATING_SYSTEM_1?srsltid=AfmBOorKSKNHOYinkg-UGPY3ZSTNbNrRTqvo5yyAkiLAvdr4lb6Gl3g9
cmcfaul 10-16-2024 02:02 PM
I have the 4 screws off and the inside of the control moduel visable. I see no place it connects to. Its the first place I looked.
Many thsnks,
Chris
proporsche 10-16-2024 02:35 PM
i wonder if it is just an option for a full automatic heater wire set up, then?
ivan
cmcfaul 10-16-2024 02:35 PM
Many thsnks,
Chris
http://forums.pelicanparts.com/uploa...1729114504.jpg
proporsche 10-16-2024 11:04 PM
as i suspected yours is semi automatic unit .If you would have fully auto unit it would plug herehttp://forums.pelicanparts.com/uploa...1729144936.jpg
cmcfaul 10-17-2024 04:47 AM
Many thanks,
Al least i know thats not the issue.
Chris
cmcfaul 10-17-2024 10:23 AM
figured it out.
Put it back together (ignoring the random wire). Checked the fuesbox and one of the relays was loose. I replaced the hood shocks while the seats were being recovered and must have knocked it loose. pushed it back in and everything works as before.
thanks again for your help.. Love this group.
Chris
89 Carrera
