Empty Relay Socket in Engine Bay
There is an empty relay socket in the fuse panel on the left side of the engine bay...
Even the picture in the Bentley manual has it empty (see circled spot) - anybody know what this would be used for? http://forums.pelicanparts.com/uploa...1729145882.png |
Not for a relay. This is the test socket for idle adjustment.
http://forums.pelicanparts.com/porsche-911-technical-forum/567228-idle-adjustment.html
this might help... Erik |
It is to activate the ABS, traction control and power steering! :p
As above, it to set the idle. |
Pop the cover off a standard black, round 911 relay, plug it in and just push the contact together to bridge the terminals.
i got for this purpose this 944 relay...with a switch
http://forums.pelicanparts.com/uploa...1729237638.jpg http://forums.pelicanparts.com/uploa...1729237638.jpg |
| All times are GMT -8. The time now is 08:57 PM. |
