'73 911 T Targa
Troubleshooting fuel sender/gauge
My fuel tank is half full.
The gauge shows 1/4 tank on the gauge after installing a new Dansk sender. Sometimes the gauge shows below 1/4 tank and sometimes it shows 1/2 tank, bit that’s kind of rare.
It sure seems like it’s the sender, but I had a similar problem with the previous sender (that’s why I replaced the sender)
How can I troubleshoot this?
Pulling the sender and farting around with it over the opening to a half full tank doesn’t seem like the best idea but I don’t know where else to begin.
Could it be the gauge?
Is there a sender that’s better than the Dansk, but not as pricey as the genuine Porsche part?
Thanks for any help.
Old 10-24-2024, 01:35 PM
Not sure if this will help, but I would pull it out and inspect it:
Getting to know the fuel gauge sender
Old 10-24-2024, 01:54 PM
'73 911 T Targa
I pulled the sender and I can hear the float moving up and down when I tilt the sender, but I haven’t tried that with the sender connected.
Old 10-24-2024, 04:27 PM
PCA Member since 1988
After screwing around disassembling and cleaning the original sender (with some success) I bought the Dansk sender a couple years ago. It works fine.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-25-2024, 12:59 PM
It's easy to test the gauge and wiring. Disconnect the sender wire at the sender and turn the key on. Your fuel gauge should be sitting at or below empty. Then touch that wire to ground (the surrounding metal on the sender should be grounded) and the fuel gauge should go to full.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 10-26-2024, 12:03 PM
