Fuel Control Pressure Test
Hi all,
Is it 1.1 bar too low for cold pressure on WUR 0438.140.089?
Thanks,
Khuong
Old 10-21-2024, 10:30 AM
Cold Control Fuel Pressure Chart……….
Use the control fuel pressure chart for your specific WUR (0-438-140-089).
Tony
Old 10-21-2024, 11:41 AM
PCA Member since 1988
You will need to know what temperature you have to use the chart.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-21-2024, 02:52 PM
Tnanks for your respond.
Below are the test result.
Fuel Control Pressure Test on 1980 Targa SC
WUR Bosch Part #:
0438.140.089
Temperature C:
17.6
System Pressure:
4.85
Cold Pressure:
1.1
Warm Pressure without vacuum / with vacuum / time:
1.1 / 1.8 / 00:00
1.8 / 2.0 / 00:01
2.3 / 2.7 / 00:02
2.7 / 3.2 / 00:03
2.8 / 3.4 / 00:04
2.8 / 3.4 / 00:05
2.8 / 3.4 / 00:06
2.8 / 3.4 / 00:07
2.8 / 3.4 / 00:08
2.8 / 3.4 / 00:09
2.8 / 3.4 / 00:10
Residual Pressure:
Closed valve:
4.8
Shut down FP:
2.6
After 10 miuntes:
1.6
After 30 miuntes:
1.6
Thanks again.
Khuong
Old 10-21-2024, 06:49 PM
Tony
Hi Tony,
I checked the graph and it looks like too low at temp 17.6 C.
Thanks,
Khuong
Old 10-21-2024, 06:58 PM
