1987 Carrera Boge Strut Pin
Finally wrapping up my front suspension refresh and want to confirm on the strut tube pin for a boge strut.
(a) the pin should be driven into the strut tube from the front
(b) the pin should be flush to the tube
Old 10-21-2024, 06:05 AM
just watched a video and they installed the pin from the back of the car. Pretty sure the manual shows the pin going in from the front.
Also, pretty sure it should be flush into the strut tube.
Old 10-21-2024, 08:12 AM
I don't have my bentley manual on hand, but it outlines the direction and orientation it needs to go in on the suspension section.
Old 10-21-2024, 09:11 AM
Not flush, 2mm stick out is normal.
206 637 4071
Old 10-21-2024, 10:17 AM
I think I misread the manual and assumed that the diagram "Front Strut" meant front of strut, however I realize now it means front vs rear.
The picture clearly shows it being installed from the rear. There is no callout in the instructions (that I can see) of which direction it needs to be installed. Does it matter?
Old 10-21-2024, 11:21 AM
PCA Member since 1988
Mine is inserted from the rear with the nut on the front. However, given the symmetry of the parts from left to right, it should not matter functionally which way they go.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-21-2024, 02:50 PM
