arrivederci's Avatar
MFI Idle Fluctuates
The idle on my '72T isn't consistent. It really is all over the place. In some instances, it won't even idle with the hand throttle fully down. Sometimes it seems like it sticks at 2000 rpm or so, but if I blip the throttle, it'll settle down to 1000 rpm. And sometimes it'll purr along at a low 500 rpm.
I'm guessing that something is sticking...but don't know where to look first. Ideas?
BTW, the flapper on the airbox has been removed. Otherwise, the complete MFI system is on the car.
- '72 911T
- '81 911SC Euro
Old 07-02-2003, 07:28 AM
304065's Avatar
Stuck thermostat. See archives for R&R instructions, clean the discs, you should be OK.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-02-2003, 07:33 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Don't know much about the mfi, except fuel is controlled by that space cam in the distributor. Maybe timing?
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 07-02-2003, 07:35 AM
Thanks...I'll take care of the thermostat.
- '72 911T
- '81 911SC Euro
Old 07-02-2003, 08:21 AM
Sounds like the "microswitch" that sits underneath your throttle linkage in the engine compartment isn't adjusted properly.
If I remember correctly, the throttle linkage arm is supposed to depress this switch when you let off of the gas pedal.
Also, is the flapper box(WUR) arm preventing the throttle bodies from closing fully? The "wheel" that sits on the end of the WUR arm on my car was making my throttle stick, which prevented the car from idling in it's proper range.
Open the engine compartment and work the linkage with your hand to see if it is sticking...
Bill
William Armentrout
1973 911T
2.7 carerra rs specs
Old 07-02-2003, 08:28 AM
Whoops...I didn't see that your flapper box had been removed...Ignore my flapper box comments...
Bill
William Armentrout
1973 911T
Old 07-02-2003, 08:29 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
The other possiblity for flucuating idle is seal between the throttle bodies and cylinder head and the seal between the stacks and throttle bodies. I belive worn throttle bodies will also exibit this problem. Check for all of those
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 07-02-2003, 08:50 AM
Sticking advance weights in the distributor ?
Old 07-02-2003, 09:15 AM
Paul Thomas's Avatar
Initially, i would not look at the MFI at all. First thing, i would check and see if my throttle linkage, from pedal to bellcrank on tranny, were not getting hung up somewhere. Next check to see if the throttle body lickage itself were lubed, working properly and not getting hung up.
If the throttle shafts were worn you would be getting popping out of the stacks and if you were getting air in under or around the throttle bodies the idle would just go up all of the time and you would get some backfiring through the exhaust.
Paul
My ignition is retarded.
Old 07-02-2003, 03:46 PM
