1977 911S turn signal and headlight issues
Just purchased a 77 911S and when I use the turn signals the right headlight goes out. Also the headlights are stuck in high beams. Could this be a bad turn signal high beam lever problem? Thanks
Common problem. Due to all the headlight power going through the switch. Here is a solution.
https://forums.pelicanparts.com/porsche-911-technical-forum/248149-turn-signal-switch-quick-fix-pictures.html You should install a head light relay set to keep the headlight power away from the switch. Our host has them here: https://www.pelicanparts.com/More_Info/JWST911HLPR.htm?pn=JWST-911-HLPR&bc=c&SVSVSI=
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 10-21-2024 at 08:41 PM.. |
