1978 Rear Wiper Relay/Fuse?
Hello
I have a 1978 930 that has a dead rear wiper switch. Its frozen and wont push down
I replaced the switch but the rear whiper still wont engage.
Question: does the rear wiper have its own relay or fuse? If so, where is it?
I will check the connectors to the rear wiper motor as well
Thanks for any input/picture of relay/fuse location
Old 10-24-2024, 06:06 PM
Kroon Wire Harnesses
The rear wiper has 2 supply's , one is connected to #30 on the rear fusebox, the other one is coming from #15 on the front fusebox, you can easily follow the 2 separate loom that lead in 4 wires to the switch. (red-black and brown-white = tunnel harness) and (red and brown = supply harness)
The wiper motor harness on the rear decklid has 4 wires (brown = ground, red = supply from rear fusebox) (red-black and brown-white are connected with the tunnel harness inside the engine bay) I suspect the fuse in the back is blown.
Specialized in Classic Porsche electrics
www.kroonwireharnesses.com
Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses
Old 10-25-2024, 12:12 AM
Thank you, will check the fuses
Old 10-25-2024, 06:55 AM
One of these 3
Are you refering to one of these 3 fuses in the rear?
Old 10-25-2024, 07:00 AM
Yes !
Old 10-25-2024, 08:07 AM
I checked both the front and rear fuses
Both looked good
Maybe motor is dead
Old 10-25-2024, 09:23 AM
Rear whiper motor hot
Rear whiper motor gets hot
And one of the connection tabs
Broke off
If motor getting hot, then brocken? Need new motor?
Old 10-25-2024, 03:53 PM
Maybe the motor itself is still good, except for the broken spade connector. It may get hot when powered if the wiper mechanism is seized.
Gilles
RoW 88 Carrera coupé
Old 10-26-2024, 01:08 AM
Motor
Looks like the motor is gone
I removed the cover. I was able to turn it by hand but its all gunked up into one ball and doesnt move under its own power
Anyone have a spare motor?
Old 10-26-2024, 07:51 AM
