-   -   Any tricks to restoring faded black anodizing? (http://forums.pelicanparts.com/porsche-911-technical-forum/116934-any-tricks-restoring-faded-black-anodizing.html)
techweenie 06-30-2003 08:21 AM
I dislike the idea of spraying black paint on the rear grille on my '73, but it's gone all the way through the purple stage to a silver-grey...
Is there any kind of treatment other than reanodizing?
Joe Bob 06-30-2003 09:08 AM
Have you tried Vaseline? They say it works on anodized Fuchs....
techweenie 06-30-2003 09:18 AM
I havent' seven *seen* Vaseline for years. I'll try it... what the heck.
BGCarrera32 06-30-2003 09:36 AM
Yes, take it off and have it reanodized...
jmohn 06-30-2003 09:41 AM
Anodizing, by itself, has no "color", it's a form of protection created by forcing the creation of a particular aluminum oxide on the surface of the part. The "black" that's fading on your car (and a couple places on mine) is paint or, perhaps more properly, a stain; usually these pieces were dipped rather than sprayed, but either is acceptable.
Jerry M
'78 SC
David E. Clark 06-30-2003 09:59 AM
What's the best way to remove the old anodizing?
IROC 06-30-2003 10:01 AM
Jerry M
'78 SC
Actually, you can anodize in different colors. Black especially is common.
Mike
KTL 06-30-2003 10:45 AM
Deanodizing. It's the reverse process of anodizing. I believe you dip the whole thing in a solution that reverses the anodizing process.
Look in the yellow pages for your local area and you'll be surprised to find how many metal finishing places might be in your area. I was. But I live in a highly populated suburban area outside of Chicago so.......
Or you can use something harsh like a lye solution. Easy-Off oven cleaner is a milder version of this.
BGCarrera32 06-30-2003 10:48 AM
You can anodize in many different colors, by adding dyes and or complimentary metals to the process. You can have the shop doing the plating chemically strip the old stuff off first, and than reanodize. You could also have them hard-coat anodize it, where a thicker and stronger anodizing is done, by cooling the chemical process with a refridgerant system (slowing down the oxidation process.) Make sure you tell them it is going on a car, and that color and uniformity are important to you. Ask to see samples if possible, or find another friend in your area who has had it done. Some shops may be unwilling to mess with your small parts, and be prepared to fork $100 or so for a few pieces.
If you are feeling creative, you could try these guys:
http://www.caswellplating.com/
-BG
Chuck Moreland 06-30-2003 10:49 AM
I love the look of the early metal grille when worn / faded. The patina gives it character, a sense of history. Wear it with pride.
jmohn 06-30-2003 11:00 AM
-BG
Quite right, almost any color is possible, but, correct me if I'm wrong, but the anodizing is done first then, if you want color, the piece is dipped in stain or dye. So couldn't you re-dye the, already anodized, piece? Or does the loss of color mean the anodizing is also lost?
Jerry M
'78 SC
BGCarrera32 06-30-2003 11:05 AM
Well, I always thought that you added dye pellets to the solution itself at the time of anodizing, but you may be correct. Perhaps they anodize, dye, and then seal it...
jmohn 06-30-2003 11:20 AM
If it is possible to just re-dye, it would certainly make refurbishing some of these trim pieces easier.
Jerry M
'78 SC
BGCarrera32 06-30-2003 11:35 AM
Yup, I'd be interested in knowing...
island911 06-30-2003 06:18 PM
. . the anodizing is done first then, if you want color, the piece is dipped in stain or dye. So couldn't you re-dye the, already anodized, piece? .. .
I do believe he is right.
Try the Rit-Dye trick. That stuff is amazing. It will find it's way even deep in between plastic molecules! Considering how porous anodize is, it should be easy.
techweenie 06-30-2003 06:53 PM
Rit Dye
Wow! That is one amazing trick (the knobs).
I bet it'll work on the grille.
I don't mind the faded-pewter color, but a P.O. had a couple of badges on the grille and they left shadows...
http://forums.pelicanparts.com/uploads/73E62503rsm.jpg
nostatic 06-30-2003 06:59 PM
What, no one else uses a Sharpie pen (permanent marker)? Works great for sunroof felt too...
GSpreeman 06-30-2003 07:09 PM
That's the trick Todd. Works for me and costs about 1/100th.
island911 06-30-2003 07:15 PM
I've seen the Sharpie pen trick on lug-nuts. It kinda looks "off" IMO. . .kinda slightly purple-ish.
Though, maybe that was Magic Marker. (?)
fogcity 06-30-2003 07:17 PM
Techweenie - where the Hell do you keep all those cars?
