1986 911 reference and speed sensor wiring
So I am putting back together a 1986 911 that I purchased in pieces. I have purchased new speed and reference sensors (the old ones were missing). I am familiar with installing them and setting them but I am puzzled by the location on the three hole bracket what goes where Does the speed sensor go in the middle hole or the reference sensor. Also is there any markings on the harness in the car to tell what goes where? Any help would be greatly appreciated.
Old 10-25-2024, 05:30 PM
The upper sensor goes in the lower hole in the bracket. DG tag may still be on the body side plug.
Edit, sorry, dg is on the middle one.
206 637 4071
Old 10-25-2024, 05:59 PM
Do these help?
Old 10-25-2024, 06:38 PM
Yes that does help. I will check tomorrow for the dg tag. So that dg tag connects to the lower connector?
Old 10-25-2024, 07:21 PM
DG goes to MIDDLE
BG to lower
Heres a better picture
Old 10-25-2024, 07:29 PM
Well I checked this am and there is no markings on the harness in the car at all. So is there any other way to figure out which one is which?
Old 10-26-2024, 05:14 AM
Just try to start the engine. If it's a no-start, reverse the connectors.
Dave
Old 10-26-2024, 06:16 AM
Yes I guess that is an option. I was just trying to figure out if there was any way to know first.
Old 10-26-2024, 07:13 AM
You can measure the AC voltage of each while cranking;
1. the RPM sensor is about 1.5 to 2.0 VAC, and goes to pins 8 & 27 on the DME ECM connector
2. the reference sensor is about .50 to .90 VAC, and goes to pins 25 & 26 on the DME ECM connector
It's that simple.
Dave
Old 10-26-2024, 03:10 PM
Thanks Dave
Old 10-28-2024, 04:40 AM
