Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Will a 3.0 liter case accept a 3.2 crank?
a buddy of mine just had a bad engine failure with a big hole in the crank case. i dont think it can be fixed. in any event, i dont see 3.2 cases for sale all that often, but i do see 3.0 cases up for grabs on occassion. would the 3.0 case accept a 3.2 liter crank? and all the other stuff?
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 10-27-2024, 02:54 PM
Black and Blue
Kemo's Avatar
i think i may be answering my own question here...and i think it has to do with the crank position sensor near the fly wheel...3.0 cases do not have that i bet.
Kemo
Old 10-27-2024, 04:02 PM
PCA Member since 1988
Yes. 3.0 cases will take the crank and other internal parts from a 3.2, but they do not have the mounting holes for the crank sensor. IDK if you can modify a 3.0 to add that.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-28-2024, 12:49 AM
What is the purpose of that sensor? Bob
Old 10-28-2024, 06:38 AM
Black and Blue
Kemo's Avatar
Bob...im an "SC" guy but i believe the crank postion sensor is used by the Fuel Injection system to control timing and what not.
Kemo
Old 10-28-2024, 09:00 AM
sensor
You have the speed and reference sensors and head temp sensor that feed info to the DME for fuel and ignition. I don't think the sensor that sits right next to the breather cap has any input. I thought it was a connect that allowed you to retrieve info, not sure what. I never have had to deal with it on repairs. Bob
Old 10-29-2024, 06:20 AM
PeteKz has a 3.2. Don't know where he sourced it but he's one of the 'go to' guys here.
Old 10-29-2024, 01:38 PM
My 3.2 runs CIS, not Motronic. It's basically a stroked SC engine.
Old 10-29-2024, 06:33 PM
