Black and Blue
Will a 3.0 liter case accept a 3.2 crank?
a buddy of mine just had a bad engine failure with a big hole in the crank case. i dont think it can be fixed. in any event, i dont see 3.2 cases for sale all that often, but i do see 3.0 cases up for grabs on occassion. would the 3.0 case accept a 3.2 liter crank? and all the other stuff?
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Black and Blue
i think i may be answering my own question here...and i think it has to do with the crank position sensor near the fly wheel...3.0 cases do not have that i bet.
PCA Member since 1988
Yes. 3.0 cases will take the crank and other internal parts from a 3.2, but they do not have the mounting holes for the crank sensor. IDK if you can modify a 3.0 to add that.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
What is the purpose of that sensor? Bob
Black and Blue
Bob...im an "SC" guy but i believe the crank postion sensor is used by the Fuel Injection system to control timing and what not.
sensor
You have the speed and reference sensors and head temp sensor that feed info to the DME for fuel and ignition. I don't think the sensor that sits right next to the breather cap has any input. I thought it was a connect that allowed you to retrieve info, not sure what. I never have had to deal with it on repairs. Bob
PeteKz has a 3.2. Don't know where he sourced it but he's one of the 'go to' guys here.
My 3.2 runs CIS, not Motronic. It's basically a stroked SC engine.
