Help with 911 3.2 muffler bolts
Hi all,
As topic states I've just purchased a Monty muffler and dansk cat bypass pipe. The hangers came without bolts and I was just wondering if anyone knows the correct size bolts in the areas if circled in red.
Since the muffler and bypass are stainless, I should be using stainless bolts also?
Thanks!
Old 10-31-2024, 10:04 PM
HarryD's Avatar
Can’t help with the size but use stainless steel bolts and Silicon/Bronze nuts. This combo will not gall.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-01-2024, 12:08 AM
917_Langheck's Avatar
If I recall correctly I used M8 40, along with a single flat washer and a split ring washer, all stainless. No galling with a dab of antifreeze on the threads. I've removed and reinstalled biannually with no issues.
The rusty hardware removed was 13mm headed, so M8 should be correct as I used the same size socket and wrench with the new hardware.
Old 11-01-2024, 01:01 AM
Should the washers be silicon bronze or stainless?
Are these good options for the nuts and bolts? I’ll worry about the size, I just want to be sure these are the right types…
Nuts
https://www.mcmaster.com/product/91776A102
Bolts
https://belmetric.com/hex-bolts-10-9-m8x1-25-coarse-din-931-933/?
Old 11-01-2024, 07:41 AM
Where did you find the monty muffler?
206 637 4071
Old 11-01-2024, 08:40 AM
HarryD's Avatar
If you exercise the hardware frequently, like you are, galling is less of an issue. For those like me, that go this every 5-10 years, the heat cycles cause the to be officially yo remove.
All parts can be SS except the nut.
Harry
2020 MB E350 4Matic
Old 11-01-2024, 09:41 AM
HarryD's Avatar
Nuts
Bolts
You should be able to get both parts from any decent nut and bolt supplier.
Harry
2020 MB E350 4Matic
Old 11-01-2024, 09:43 AM
Just have one sitting
Old 11-01-2024, 03:43 PM
Is there a reason against stainless nuts?
Old 11-01-2024, 03:45 PM
na2ub's Avatar
Yes. I found this out last year when I installed my muffler. Stainless bolts and stainless nuts tend to destroy each other when you torque them down, and get seized (gauled) so that they are super difficult to remove. I ended up just getting cad-plated hardware from Autozone, but stainless bolts and brass nuts seems like a great no-rust solution.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 11-01-2024, 04:21 PM
I never use SS hardware. Standard old cad plated stuff always worked for me. Just had to remove 3 SS bolts and nuts on a Carrera muffler. PITA.
206 637 4071
Old 11-01-2024, 04:48 PM
Wouldn't it be easier to use zinc nuts and bolts?
Yes zinc and stainless can cause galvanic corrosion, but the muffler will never really be wet.
Old 11-01-2024, 04:54 PM
