Newbie Q - those clips for the crank sensors on a 3.23 Carrera?
Hello, FNG here...
[1988 Carrera 3.2] Just replaced my head temp sensor and even though I bagged the various parts of other things I took apart - I still managed to lose one of the crank sensor clips - those square-ish wire things that hold the VAG plugs to the harness. I don't even see a part # in the Porsche parts catalog for them. I can rig something up but I would much prefer to do it right and do it once.
Do the new replacement sensors come with them?
I have tried to search the forums on this one but not seen anything.
Thank you for any advice.
Old 11-07-2024, 06:53 AM
917_Langheck's Avatar
Search for junior timer parts
By coincidence just came across this page: https://www.carpokes.com/viewtopic.php?t=565
Old 11-07-2024, 08:21 AM
Newbie Q - those clips for the crank sensors on a 3.2 Carrera?
Thanks! That's a big help. I had no idea what they were called.
Mouser seems to have a great selection by the way, although it appears that the newer models have those clips integrated. I'll probably buy a couple that are as close to the correct size as I can find and see if I can re-use a clip from one.
This one looks pretty close to the "pulse sensor" connector:
https://www.mouser.com/ProductDetail/TE-Connectivity-AMP/282762-1?
The whole selection is here if anyone else is looking:
https://www.mouser.com/c/connectors/automotive-connectors/?m=TE%20Connectivity&series=Junior%20Power%20Timer
Old 11-08-2024, 07:00 AM
