KW V3 Spindle/Hub Installation Problem
Hi Everyone,
I'm rebuilding the suspension on my 1980 911 Turbo. I bought a pair of KW V3 shocks and ran into a problem with the installation. I decided to use my old bearings (they look good) but when I go to put the hub on the spindle, it gets stuck. The hub/bearings will not go on all the way. I can get it to where it will just about go onto the inner spacer. When I go try on the old spindles, it fits no problem. Also when I get them partially installed on the new spindle, it is then very difficult to remove. This problem happens for both new spindles (right and left). In the KW V3 Installation instructions it says "Pay attention to a clean and zinc-free surface of the axle journal. Remove the zinc coating with a fine sandpaper or abrasive fleece". Does this mean I need to sand down the spindle? Has anyone had this problem or have any ideas. |
Yes, you need to very carefully remove the coating. I had to do it to mine as well. Why they have chosen to go down this path is beyond me. Seems like opening the door for amateurs like me to F it up
The official response from KW is...
"Only the area where the bearing ring will sit has to be sanded carefully until it’s zinc-free, otherwise it’s not possible to mount the ring. " I installed the bearing ring (spacer that does most towards the rotor) and its o-ring no problem. I'll write back and see what they say. |
Wow interesting. Perhaps it is to obtain a really close bearing tolerance? Or to protect the surface while shipping?
Why wouldn't they compensate the journal size for coating buildup or mask it? Masking the spindles would add $10 max to the plating cost and save a ton of headache for the consumer.
Wow Pretty ridiculous that a company like KW can't do the finishing steps themselves, or account for the additional thickness/mask so it isn't a problem. Doesn't seem smart to require amateurs to remove material from a sensitive area on your parts.
I'm glad I saw this - I have a set shipping to me right now. I'll measure them when they come in and calculate plating thickness.
KW sent me the following for measurements for the spindle. I'll take some measurements today.
http://forums.pelicanparts.com/uploa...1731400888.png |
I bought some new bearings to see how they fit. Will update this weekend
*Update*
I tried to see how new bearings fit on the spindle and...... they don't. They get stuck right away. The spindle is just a little too big, so I am hoping just some sanding of the surface paint will allow them to slide on. I'll be messaging KW about this and keep everyone updated on the response. |
My set cleared customs in Chicago last week and were "out for delivery" before our friends at FedEx routed them to Memphis. They'll theoretically dock tomorrow.
The coating feels "plastic-like", which is good for the exposed portions but needs to be removed from the bearing surfaces. Best guess, there's about .05mm interference due to the coating. I didn't have 600 grit emery cloth handy and didn't want to use anything rougher. I'll measure again once the coating is removed.
http://forums.pelicanparts.com/uploa...1732026302.jpg http://forums.pelicanparts.com/uploa...1732026302.jpg http://forums.pelicanparts.com/uploa...1732026302.jpg |
Following. I want to install struts with raised spindles and 3.5" caliper mounts in my 1973 car. Not too many late Carrera front struts available, so I'm considering just going with the KW struts to replace my current OE Boge 3" caliper struts with Koni Sport inserts. I want to know how this eventually turns out for you.
Pete, I have them on my car and am happy. Just a tad annoyed having to manually remove a coating, which should have been done by KW before leaving the factory
What strut inserts did you have previously? Are the KW noticeably better, and how so?
It's a shame they switched to paint from their previous plating, they were just so gorgeous!!! But also explains why the need to remove the paint from the bearing area. Expect to have to do it for the inner spacer and outer bearing race.
Depending on your wheel size people have had issue with 19mm raised spindles and 15" wheels, I had to great creative with a grinder to clear the 15x7 fuchs on the front of that car. Also, you must, must, must correct bump steer when raising spindles. I ended up using 42mm of spacer to get it right. Getting rid of the bump steer made a huge difference in the handling of the car. This thread will point you in the right direction: https://forums.pelicanparts.com/porsche-911-technical-forum/1116600-19mm-raised-front-spindles-adjustable-bump-steer-no-4.html |
Jonny, thanks for the feedback. I'm aware of the need to correct bump steer. I currently have the spacer kit on my car. I know that's not enough for a 19mm raised spindle.
With the added suspension travel (and a decent bump steer curve) you could soften the front of your car up to 19's, and leaving the 26's in rear would be a great match. I just had to dig up this old post regarding the ride frequencies and the learning curve I went through with the Project: Quote:
here''s a summary of street oriented effects from t-bars on a 2650# Carrera w/ stock 20/18 underbody sways>> track, sways and shock pressures all affect this, your effect will be reflected in that
http://forums.pelicanparts.com/uploa...1732231452.jpg http://forums.pelicanparts.com/uploa...1732231452.jpg http://forums.pelicanparts.com/uploa...1732231452.jpg |
So the data above is a min. Tell me why it can't be considered as a spring rate |
The only increase in the force exerted by gas pressure through the shock stroke is due to the additional volume the shock shaft is taking up as the shock travels in bump, and it's very small as a proportion of the overall volume. If I had to guess it's a few pounds increase, if that. That 42 pounds can simply be considered as preload that the torsion bar doesn't have to deal with and it's not a dynamic component. |
And, even though I'm the last person that should be checking anyone's math, there seems to be something broken in the total/sprung/unsprung section that might be throwing off the frequencies as well.
Yes, the shocks also affect the suspension frequency. It's a "mass-spring-damper" equation, and because the shock damping increases as V^2, it's a non-linear frequency response. Same math as the RCL equations in electrical engineering.
PV = nrT again I don't know what the slope is, just that it is constant |
in the charts I did figure a nominal damping rate but it isn't used for anything, I was just curious how it compares to the published damping curves for the various varieties of Bilstein |
I'm not saying shocks don't affect the suspension, we're just talking about the simple calculation of how "stiff" either end of the car is. Like a weight bobbing on a spring, heavy weight on a soft spring bobs slowly, light weight on a stiff spring bobs quickly. Damping is not figured in this calculation - it's something you add to manage the resulting characteristics after the fact. This simple calculation results in a Hz value which is then commonly thrown around like Bill has at the bottom of his spreadsheet. I'm not making this up. First hit on google: http://forums.pelicanparts.com/uploa...1732372574.jpg |
PS - I'll try to ignore the insulting and irrelevant dissertation on how linear doesn't mean doubling.... to double the compression on a linear spring the force needs to double. Can you please make an effort to understand what I'm saying instead of going straight to insulting my intelligence? |
the compressed force can be measured but I didn't and don't have that information from any other source canister pressure which is the source of the shock force is a tuning tool for shocks like MCS and JRZ I use it because its there and the 42# is a minimum #, none of these #s are what one could call precise, there are all sorts of additional factors like the tire spring rate, scrub rate and stiction forces at play |
the unsprung &sprung isn't used elsewhere only the track is used to calculate roll rates I did fudge the corner weights and used a theoretical 40/60 split instead of the actual measured #s from my car, the actual measured f/r ratio is 39.5/60.5 & 2594# |
yes the 42# at full extension is a preload. the preload increase w/ compression and is proportional to the internal gas pressure described by the rule PV - nrT if the gas chamber volume is halved the pressure and temperature go up, some of the energy goes into P inc and some goes into T inc, I don't know the ratio there. Internally there is a nitrogen gas chamber separated from an oil filled chamber, the gas volume is compressible but stays in the chamber, the volume, pressure and temperature of the gas in the chamber varies in proportion to the shock piston movement, the pressurized gas forces the relatively incompressible working fluid through various orifices to damp the motion and shape the damping curve. the #s in this diagram are notional not specific to a 911 http://forums.pelicanparts.com/uploa...1732387150.jpg the gas pressure pushes the chassis upward just like a spring, the min. value for this upward push is ~42# the max is unknown to me if it walks like a duck and quacks like a duck treat it like a duck http://forums.pelicanparts.com/uploa...1732388437.jpg http://forums.pelicanparts.com/uploa...1732388437.jpg http://forums.pelicanparts.com/uploa...1732388437.jpg |
I tend to agree with Jonny about the pressure inside Bilstiens acting more like preload than additional spring constant. However the way to find out is to put a Bilstien on a scale and press down on it at the top of the stroke and the bottom of the stroke to find the spring constant. I don't have time to do that this weekend because I have a plumbing project to finish--house plumbing, that is, "honey do" list.
Jonny, the equation you found with Google is a first order approximation, good for comparing the suspensions when just changing the springs. As I said before, the damping contributes greatly to the suspension frequency response and "felt stiffness." You probably know that too. For others following with a casual interest, consider the difference in response for a shock with very little damping, versus a shock with a LOT of damping. In the first case, the suspension will bounce up and down a lot before ironing out, at pretty close to the sping/mass frequency Jonny cited above. But with a lot of damping, that movement will be slowed considerably--thus necessarily decreasing the suspension frequency--even though it makes the ride feel much stiffer. That brings up something I emphasize frequently: The harshness of the suspension that you feel in your butt depends more on the damping (shock stiffness) than the stiffness of the springs. You can prove this to yourself if you have adjustable shocks (like my Koni's) by setting the shocks at their softest and then comparing to the settings at their hardest. Big difference, with the same springs/T-bars. And, yes, shocks with digressive valves or other valve designs complicate these relationships further. I find that for a street car, I prefer moderately stiff springs/T-bars, with moderately soft shocks to tame rough roads and maintain a reasonably comfortable ride without too much roll or wallowing. Race cars are a different case. |
Just barely compressed: http://forums.pelicanparts.com/uploa...1732405901.jpg Almost fully compressed: http://forums.pelicanparts.com/uploa...1732405901.jpg So, the effective spring rate of the gas charge is less than 1lb/in. |
still its a 42# shock rate * .9 to get wheel rate added to the t-bar rate an 18.8mm front w/ wheel rate of ~110lb/in becomes ~148l b/in + ~4# at full compression for ~152#/in max |
Which is the whole point I'm trying to make, and the reason the ride frequencies you're coming up with are so high. Does it not strike you as odd that your calculated frequencies are double that of a typical passenger car? |
| All times are GMT -8. The time now is 11:23 PM. |
