-   -   911SC Fan Grind Marks (http://forums.pelicanparts.com/porsche-911-technical-forum/1170004-911sc-fan-grind-marks.html)
Jaymanbikes12 11-10-2024 03:55 AM
http://forums.pelicanparts.com/uploa...1731242931.jpg
I recently acquired a 911SC, i wanted to clean up the tired looking fan and shroud. This pic is after vapor honing. As you can see it appears someone used a grinder on the hub of the fan for some reason, any ideas as to why they may have done this?
mepstein 11-10-2024 04:06 AM
More likely the fan was loose or improperly adjusted and was damaged during use.
E Sully 11-10-2024 05:21 AM
The grind slots to create the flats sides are normal on early fans from the factory, as seen on these fans. As mepstein suggests, yours seems to have a little welding done to fix some kind of issue. You could probably have it fixed up a bit with some careful grinding. It would most likely need to be balanced.
http://forums.pelicanparts.com/uploa...1731248056.jpg
http://forums.pelicanparts.com/uploa...1731246928.jpg
http://forums.pelicanparts.com/uploa...1731246960.jpg
porschedude996 11-10-2024 07:19 PM
The steel hub can be replaced. I think they are $150.
