http://forums.pelicanparts.com/uploa...1732816706.jpg
http://forums.pelicanparts.com/uploa...1732816706.jpg Right rear. http://forums.pelicanparts.com/uploa...1732816706.jpg Coating has blistered look. http://forums.pelicanparts.com/uploa...1732816706.jpg Adjustment hole is present. It’s in face of hubs—-I was looking for it on the side. http://forums.pelicanparts.com/uploa...1732816706.jpg Soft lines are in good form all around. Forgot to check right side wheel bearings. Testing parking brake over the next day or so. If good, will fill fuel tank and start city mpg test anew. Recheck rotor temps too. RR should fall in line now. Swapping #4 & 6 injectors tomorrow morning. . |
Cruising AFR is probably more relevant to fuel economy than idle.
If the plugs all look the same and are not super sooty then it's unlikely fuel injector(s). That leaves ignition misfire, which should be felt as lack of power. Or lack of advance (not applicable with DME?). Cam timing could be off from bank to bank... A quick dyno might be useful. You could also send out all the injectors for a flow characterization if that's still a doubt. |
A properly running 3.2L with no O2 sensor (in open-loop) should see these AFRs:
- Idle 13.8 to 14.4 - 3000RPM in 4th gear steady state on level road 14.4 to 14.8AFR - WOT needs to be below 13.0 at all times, stock chip may be in the 11s All AFR testing done on fully warm engine. |
You'll see where status is below. . |
#6 and #4 injectors are now swapped. Have also reinstalled O2 sensors from Innovate. (Bylund sensors are removed.) Prior and new cylinder balance for 4-5-6…
http://forums.pelicanparts.com/uploa...1732995406.jpg Cylinder balance prior to swap. http://forums.pelicanparts.com/uploa...1732995430.jpg Cylinder balance after swap. …Not what I expected. Note for file… Injector that was in #4 cylinder is a recent replacement for one of the original Bosch 158 injectors that failed a few years back. Back then I replaced the 5 Bosch with Lucas (from Five O) given the cost of even a used 158 at the time. The Lucas do have 18 mpg city to their credit as they were installed and operating prior to the rebuild. For testing purposes during this 10 mpg puzzle solving, the Lucas were removed and the 5 original Bosch 158s (that were good and in storage) were tested together with the replacement just acquired. ALL injectors proved in good form and were installed. Is Idaho Bill who tested these injectors. His report is posted earlier in this thread. http://forums.pelicanparts.com/uploa...1732995592.jpg The newly acquired injector at right has the Bosch part number molded into the neck as do the originals at left. Dimensions match but the discharge ends are clearly different. Whether this matters or not is questionable. According to Bill’s report, the flow of all the installed Bosch injectors match. Sal highlighted the fact that 3.2 manifolds have an off-center throttle body, result of this being a slight + bias of air flow to 1-2-3. Makes sense then for 1-2-3 to naturally run slightly leaner than 4-5-6. Is that bias seen here… After swap of #4 and #6 Warm idle Mixture screw 5 turns out: http://forums.pelicanparts.com/uploa...1732995717.jpg If the imbalance is a delta of airflow to 1-2-3, and, possibly caused by the throttle body’s offset position, a way (not “the” way) to correct for it is to adjust fuel flow to either side of the engine. Perhaps the engine and we have already been witness to this “correction.” That being with the “combo” injector config—Bosch in 1-2-3 and Lucas in 4-5-6… Bosch-Lucas injector combo - old test (Before swap of 4 and 6) Warm idle Mixture screw 5 turns out: http://forums.pelicanparts.com/uploa...1732995825.jpg Looking at this, it would seem the Lucas injectors flow slightly less than the Bosch. Sufficiently less to apparently compensate for whatever is going on… throttle body offset? On the subject of air, worth saying the rebuild provided the engine new intake spacers, new intake gaskets top and bottom, and new intake nuts that are confirmed tight. Ignition components, injection harness, and ECU have been checked. There was a loose vacuum hose at the boster’s Y but that’s now tight with the oil cap confirming no vacuum leaks. All this stuff and testing doesn’t “100% guarantee” anything but does slant probability towards something else… throttle body offset bias perhaps. When Lucas injectors return from Idaho Bill, am returning Lucas to 4-5-6 and leaving Bosch in 1-2-3. Do some testing afterwards. That’s the plan concerning the “imbalance” between sides. 10 mpg puzzle Been working parking brake now (after rebuilding both sides,) driving, and shooting new rotor temps multiple times yesterday. Below, in next post, are three samples taken from the many that all say the same thing. I mentioned not using the parking brake much… Thinking it through, I “move” the parking brake more frequently than I realized. This is to clean the center console tray. To vacuum. Recently to do wiring. Car sitting idle for 18 months while the engine was being rebuilt, and this being in the humid conditions this car exists in… not good. Put all this together and dragging parking brakes makes sense. The odd twist to this is my having checked the car’s free roll on a few occasions during this 10 mpg puzzle solving. Had I caught anything along the way… red flag. No flags. It must be the drag came and went. Backing up does release the p-brake and of course backing up happens quite often. What new rotor temps say is not taken as proof the dragging p-brakes were the cause for 10 mpg city. Am taking what’s seen as a preliminary indicator of something positive. Tank has been filled at Westar (to keep that brand of fuel in the tank for now.) City mpg test in progress. . |
Based on Sal bringing up throttle bias towards 1-2-3, been digging into that. Found Gliding Serpent's 3.2 intake flow test. Credit to him for the pic and CFM data. Glider’s thread: https://forums.pelicanparts.com/porsche-911-technical-forum/862450-3-2-intake-plenum-flow-testing-interesting-results.html
http://forums.pelicanparts.com/uploa...1733276634.jpg CFM air flow: #1 261 #2 251 #3 252 #4 245.5 #5 248 #6 238 Figures above charted... http://forums.pelicanparts.com/uploa...1733276939.jpg Assuming this data is correct and it’s a standard for 3.2 manifolds, the O2 imbalance side-to-side seen in my engine (with 1-2-3 leaner than 4-5-6 and with either all Lucas or all Bosch injectors)… puzzle is coming together bit by bit. If returning to the combo of Bosch inj in 1-2-3 and Lucas in 4-5-6 does not even things out as it did previously, a tuneable air bypass comes to mind. Combo of injectors may not do what is desired given Idaho Bill having serviced the Lucas injectors before I could stop him. . |
Induced air leak into intake manifold...
Is to see if 4-5-6 side (blue trace) went any leaner... and how much 1-2-3 side would be affected. Warm idle idle mixture screw out 5 turns All Bosch injectors http://forums.pelicanparts.com/uploa...1733423885.jpg Loosened then retightened right hand clamp on rubber collar that joins the intake manifolds. Idle drops and becomes very slightly rough. When tightened, idle returns to where it was. Doing this a few times, I found O2 very sensitive to nearly any turn of the clamping screw after the seal is compromised. Chart is with quick turn of the clamp-screw and between 1/4 and 1/2 a turn. Waiting on Lucas injectors from Idaho Bill. . |
Your idle AFR imbalance does not explain 10 mpg. I think you're barking up the wrong tree. What do the numbers look like when cruising down the highway at steady state?
Highway cruise with either all-Lucas or all-Bosch injectors is imbalanced. 1-2-3 is lean compared to 4-5-6. I did not test highway cruise with the Bosch-Lucas combo but believe a near balance would exist. Bosch injectors: 0280150158 (original to this 3.2) and Lucas: 24lb. low impedance from Five-O. http://forums.pelicanparts.com/uploa...1733482312.jpg This is WOT to redline in 1st, 2nd, 3rd with the Bosch-Lucas combo installed. There's a hint of cruise in this. Re the O2 imbalance, it's possible this being due to the offset of the throttle body and the resulting bias of + air flow to the 1-2-3 side. Look at Glider's 3.2 manifold flow data that I posted earlier... Assuming the shop that did this for Glider got it right, it suggests an inherent imbalance in 3.2 intake manifold design. Surly Porsche engineers tested intake flow and if what Glider posted is indeed accurate, I assume Porsche concluded the 3.2 intake's imbalance being acceptable. I may be splitting hairs over the O2 imbalance in hand but since I got O2 very close to being in balance side-to-side at one point---with the Bosch-Lucas injector combo---makes sense to set that combo up again and see what happens. Am waiting on Lucas injectors to get back to me in order to reinstall them in 4-5-6. Because the Lucas have been "serviced" by Idaho Bill after the combo config was tested (and near balance was achieved,) there's no telling what O2 will be seen now when this combo is run again. Leaking air into the manifolds yesterday was revealing. Even a small adjustment to what air was allowed in was instantly realized in combustion/exhaust. I have a new found appreciation for what our AFMs accomplish when an engine's fuel trim is on target. |
Looks to be about 3% difference (as measured) between the banks. Lots of tolerance stacks there, so some of it could be real and some could be just normal noise.
Intakes are a dynamic system. If you get idle balanced, it doesn't mean that they will be balanced at other RPM/flow conditions. If you measure AFR by cylinder, you'll see some cylinders that are richer than average at some points, and leaner than average at others. Here's a good video showing effects of AFR on power/torque: https://www.youtube.com/watch?v=yjvPmG123nI The goal is to get two squigely lines to overlay each other? Or is there also another metric? |
Bosch 0128150158 compared to Lucas D1540BA…
http://forums.pelicanparts.com/uploa...1733694141.jpg http://forums.pelicanparts.com/uploa...1733694141.jpg http://forums.pelicanparts.com/uploa...1733694141.jpg Bosch-Lucas combo are reinstalled… Combo Retest Warm idle Bosch in 1-2-3 | green Lucas in 4-5-6 | blue Mixture screw out 5 turns - until balance is achieved, leaving mixture at 5 turns http://forums.pelicanparts.com/uploa...1733694305.jpg Given 1-2-3 side of intake manifold being + air flow compared to 4-5-6 (per Glider’s testing,) why 1-2-3 side now running richer than 4-5-6 side is another mystery. http://forums.pelicanparts.com/uploa...1733694404.jpg Bill's Report. Lucas are now—as installed—flow matched to Bosch at 260 cc/min. Injector from #6 is unlike others. Previous Bosch-Lucas combo O2 result. More I mess with things now, more I appreciate what had occurred here: http://forums.pelicanparts.com/uploa...1733694573.jpg Was tempted to leave combo config as it was at the time and walk away… couldn't. Lucas injectors are different now because I sent them to Bill to test them. Didn’t want him to service them but that got lost in translation. Going to swap injectors side-to-side. Before doing so and with the engine cold (just started it)… Cylinder balance test COLD idle Bosch in 1-2-3 | green Lucas in 4-5-6 | blue http://forums.pelicanparts.com/uploa...1733694700.jpg Injectors are now swapped side-to-side… After the swap test Slightly warm idle (impatient to see outcome) Lucas now in 1-2-3 | green Bosch now in 4-5-6 | blue http://forums.pelicanparts.com/uploa...1733694919.jpg Lucas lean delta from 1.0 lambda and Bosch richness from same has increased after swap. . |
Wideband spiking solved
http://forums.pelicanparts.com/uploa...1734023974.jpg
http://forums.pelicanparts.com/uploa...1734023974.jpg 1-2-3 side has progressively soured over the last few days. Sensation = going backwards! (Wideband business has been a whipping post of sorts. No complaint. Is clearly a necessary evil to embrace.) Questioned/tested sensing gear. Ignition. Fuel. Culprit = one or more of the Lucas injectors in 1-2-3. During this fault-hunt, found Innovate extension cable---serving 1-2-3---to have gotten scorched. Cable was run ahead of the engine from left to right. Exact position is uncertain. Should have stuck camera back there to check. Insides of cable are now just barely exposed. Tested cable as it is. Not at fault here. New 8’ extension is installed. Revised run avoids whatever the hot-spot was. New passage is now completely along outside perimeter of engine bay connecting with sensor cable on 1-2-3 side in the engine bay. Sensor is notably from Innovate---sensor cable lengths vary depending on sensor's source. This new run with 8’ length leaves just enough in-cabin cable so extension cable’s junction (that connects to the controller) sits between the squabs. My cable passage from cabin-to-engine-bay is at bay's forward, passenger-side corner. 10' extension cable would be preferable. Innovate's next extension longer is 18'. My Innovate system is portable for the time being. Have yet to decide if making it permanent has appeal. Removed Lucas from 1-2-3 and Installed Bosch 158s in their place… All Bosch injectors installed 2 new & calibrated 4.9 sensors New 1-2-3 extension cable Warm idle 1-2-3 = green 4-5-6 = blue Idle mixture screw 5 turns out http://forums.pelicanparts.com/uploa...1734024404.jpg "Leave it alone now you idiot!" would come from someone I know. NP. Lewis & Clark syndrome... Must see what happens with existing Bosch 260cc injectors in 1-2-3 and to-be-installed 255cc injectors in 4-5-6. Trust is in specs & reports in this exploration---and we know those are always spot on. ...255s in transit. ...City mpg still in progress. . |
The average flow per runner for 1-3 side is 255 and the 4-6 side is 244 that's a difference of 4.5% favoring air flow to the 1-3 side.
If 4.5% more air flows to the 1-3 side that means that side should read 4.5% leaner than the 4-6 side. The math is usually correct. The last pic you posted with all six same 158 injectors looks like the green 1-3 side is at about 0.98lambda while the 4-6 side 0.94 lambda. So, 1-3 side is leaner than the 4-6 side by about 0.98/0.94=4.3% that matches the runner flow difference. At this point you are done, side to side is withing 5% on AFR, I've known for a long time that the air flow favors the 1-3 side, it's simply the manifold design. I know the flow data you found from Gliding S. is correct I helped on that build with him :) his car was tuned by me when he installed my MAF setup. The owner John D. is meticulous! Keep in mind those flow numbers are done at extremely high flow rates above 200cfm but in reality at 7000RPM a 3.4L will only draw in about 60CFM at most, no where near those 250CFM numbers! The intake plenum is not a restriction in these engines. How the runners behave on a flow bench is NOT how they behave in car, but the flow bench data is still telling about the overall design of the plenum. Quote:
To speculate... if it's possible to get AFR so both 1-2-3 and 4-5-6 are at 0.95 lambda at warm idle, would seem both sides then have optimal O2 symmetry. Or, would that O2 symmetry with the bias of intake air flow to 1-2-3, and let's suppose a reduction of fuel to 4-5-6 to create the O2 symmetry, would this have the 1-2-3 side running with a slight bias of power? PS - my iphone is out of order for another day or so. . |
I'm slightly confused now, are you saying you sometimes have both sides at 0.95lambda with fully warm engine at idle?
The most important test is part throttle steady state load, 4th gear 3000RPMs what's the lambda in each bank? Can you please do that test when you have time? Idle conditions can be very finicky to get perfect mixture because flow rates and injector time are both very low. |
I'm also confused by Porsche would design in an imbalance in their manifold. I find this perplexing. It's true, the distances from the common plenum to the the intake may be different, but I can only assume that balancing the overall vacuum/flow to each cylinder was considered in Porsche's simulation, calculations, and testing. I could be wrong as it's only an assumption. |
<iframe width="560" height="315" src="https://www.youtube.com/embed/GAlRONoOUGk?si=A-HNISGFPGtGiLNz" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
Must be flow data is relative to the manifold being tested. I say this because while cc flow is mentioned, nothing is said about what vacuum force is being applied. Obviously that vacuum must be the same for a single manifold. But could be different from one manifold to the next. And different shop to shop---unless there is an applied standard. Posted vid as some ref to how this is done---I had no idea. Loosing sleep over the math on hand, calculations on paper are called for. Am going at this slightly different than Sal. And this is to play with numbers---am not seeking Nobel calculus prize here. And certainly not competing with Sal. Curiosity that's got hold of me is the air flow delta side-to-side in my 3.2 intake. Without Gliding Serpent's ("Glider's") air flow figures, I'd not be at this---TY Glider. Never mind how his numbers were arrived at, or what the reality of air flow is in a working engine, or the potential infinite variables involved, am plugging numbers in to see what comes of it... Question being, can we do the math and sort out what injector flow rate is wanted for one side of an engine when we already know the air flow rate, AFR/Lambda, and flow for injectors already in an engine? This assumes there's an imbalance in O2 side-to-side and the goal is to improve O2 balance. Not saying this is necessary to do or not... doing it to see if it can be done. Empirical stuff. Added each side's cfm per Glider's data: 24 lb. 255 cc injectors should arrive later today. (Ordered these injectors a few days ago based on "dirty" Lucas test results.) Will install them tomorrow morning and run a log. IF... and that's a big "IF", all the numbers applied work, the result would be an AFR/Lambda which brings 4-5-6 O2 closer to the 1-2-3 side than the last log with all Bosch injectors installed. But 4-5-6 O2 will not go above 1-2-3. So 4-5-6 will still be slightly richer than 1-2-3. A speculative prediction. Am fully prepared to eat crow. . |
This is the "balanced" test with the Bosch-"dirty"Lucas combo: http://forums.pelicanparts.com/uploa...1734107203.jpg Re the 4th & 3000 rpm testing... will do with the all Bosch set up as is installed now. Then a comparison with the Bosch and new 255cc in 4-5-6. Post those tomorrow / Sat. late in day. . |
I don't think the intake runner flows are that bad, reason the flow bench looks bad is they are flowing them to max flow. But in reality these runners only flow 60CFM at most at WOT 7000RPM.
I tend to agree the engineers had already sized them properly. Quote:
Just throwing this out there,
at low duty cycle the latency of the injector has a much more profound influence on mixture, so it you have injectors with different flow rates that also have different latency, you may balance mixture at one pulse width but negatively effect that at a different pulse width. |
Agree, at very low flow rates is when old injectors act up the most. They have trouble turning on and off and often have bad spray patterns.
This is why I'm suggesting to check fuel ratio at moderate load in 4th gear 3000RPM steady state driving. Quote:
http://forums.pelicanparts.com/uploa...1734198373.jpg
255cc Injectors from Five0 arrived. Don’t fit. Bottom, fixed o-ring O.D. is too large. Appear remanufactured. Logs here are from today. Bosch 158 injectors in all cylinders. Green = 1-2-3 Blue = 4-5-6 Red dot-dash = 1.0 lambda Cold engine at idle Immediately after start up: http://forums.pelicanparts.com/uploa...1734198616.jpg Warm engine at idle dash temp gauge at 210: http://forums.pelicanparts.com/uploa...1734198616.jpg 3,000 rpm standing still / no load: http://forums.pelicanparts.com/uploa...1734198616.jpg 3,000 rpm in 4th gear, level pavement: http://forums.pelicanparts.com/uploa...1734198616.jpg Fine suggestion to look at 3,000 Sal. Touch lean under load? . |
Your 4th gear 3000RPM is spot ON!
Next, same 4th gear 3000RPM go WOT but ride/hold the brakes at the same time to hold engine at 3000RPM. Do not do this for more than 5 seconds as you'll super heat the brakes. In that 5 sec window record the AFR, it needs to be below 13.0 or 0.89lambda but with a stock chip you may be much richer and with aftermarket chip like SW chip you'll be in the 0.84 to 0.89 range and stock chip can be down in the 0.80 to 0.84 range. The important thing is that at WOT you should always be below 0.89lambda. If you really want to test some other injectors I can recommend trying a set of Ford OEM Racing injectors, but you will need to make a few special adjustments to run these. Let me know if you want guidance doing that. The injectors are top notch FORD 24lb purple injectors, they will need a grove cut into them for the retainer clip but I can do that for a small fee. FORD OEM part # M-9593-LU24A https://www.amazon.com/Ford-Racing-M-9593-LU24A-Hi-Flow-Injector/dp/B00E89UBMG And do not get knock offs they are junk! Only buy from the FORD Official Store on Amazon! They will need these adapters also: https://www.amazon.com/dp/B0BYZMRYZ3 But these will run slightly lean, good news is you can simply move the Fuel Quality Switch in the DME to 3 or 6% richer. Or you can do a little fine tuning of the air meter wiper arm and move it slightly higher up to richen things up slightly. You have WBO2 readings on both banks so you have the tools to dial in the mixture. Stop messing with old school single pittle injectors we have much better modern day tech! Or eventually install my MAF System and get spot on fuel mixture and the very best performance and throttle response. |
WOT w/braking in 4th gear to hold 3,000 rpm, 5 second brake hold
No wings to this. Increased braking while nearing 3,000 did not see O2 below 0.89. Did not save log figuring on redo. Tried braking down from near redline to 3,000. Brakes did not bite with WOT. Perhaps standing on the pedal would have worked... but didn’t apply pressure to system beyond my comfort zone. Mintex pads. Drilled rotors of a forgotten brand. To further impose on the brakes while possibly gaining a technique for this test... didn't go there. WOT to redline through gears All Bosch 158 single pintle antiquitous injectors Green = 1-2-3 Blue = 4-5-6 Red dot-dash = 1.0 lambda Blue dot-dash = 0.89 lambda http://forums.pelicanparts.com/uploa...1734288041.jpg Safe pavement runs out in 4th so throttle comes off very early in that cycle. Sides slightly inverting under WOT… curious. Were it not for your relentless prodding to wideband the engine Sal, can’t say where I’d be with this fuel puzzling. Ford racing injector note is appreciated. Seeing the loaded 3,000 4th gear test, and WOT-to-redline with O2 below 0.89, obsessing over injectors (balancing sides) is done with. Focus gets back to where this fuel journey began… 10mpg city. Parking brakes proved to be dragging… but… also eluded my car-push test not once, multiple times. There’s oddity in this. A haunting concern lingers: Can 10mpg city (and 27 highway) result from my installing 964 Webcams / 40ie grind, and setting 1.45 overlap? Your MAF system… studied data you provided me on that. Brilliant solution. You certainly have a gladiator-mind for this air-fuel arena. Impressive is an understatement. To add another 911 project to my life cannot be allowed at the moment—other fish must be fried. Also would be pleasant to drive more & wrench less for a while—if at all possible. Old, single pintle injectors duly noted… antiques as they are, they must also fall into out of bounds territory for the moment. In a few words: car/engine has never run as well as it does now, 10mpg aside. Progress / results here… much to your credit Sal. Thank you for your shared wisdom :) |
Your WOT AFR numbers are fine. At this point just set idle mixture on the 1-2-3 side at 0.96lambda and you are done for now.
Your 27MPG on the highway is a very good MPG for these engines. Why you see 10MPG city is very strange if it's not the brake issue? The 40i40e cam is actually a slightly less aggressive cam than the factory 964 cam. I never set cams using overlap method because it's not perfect, it depends a lot on having the valve lash properly set. I always prefer setting a cam using the LCA method, where you find the exact point where the cam achieves peak lift, this method does not care about the valve lash. If the cam is a 113 LCA and you want it installed perfectly and not retarded or advanced it's very easy to do. You just set it so peak lift occurs at exactly 113deg ATDC on the intake lobe and your done! |
These are what's used in my MAF System, they are Bosch OEM Racing program injectors and they are 34lb injectors. Can fuel a 4.0L if you could build such an engine. These are modern day top notch Bosch 4 hole disc injectors.
http://forums.pelicanparts.com/uploa...1734296408.jpg http://forums.pelicanparts.com/uploa...1734296424.jpg |
Will see in a few days where city mpg lands. From looking at my fuel & odo gauges right now, 18 mpg does not appear to be happening...but it's early. To fill, I allow pump to auto shut off so might not have started with a truly "full" tank. Westar fuel (using a particular pump) is currently being tested. Thanks for 964 cam comment. Had you said "Yes, they gobble gas," that would have been disappointing. Your peak lobe timing technique... wondering if this requires rotating the cams forward and in reverse to determine a lobe's precise peak (like determining precise piston peak.) If so, wouldn't chain slack play in? If it does, you must compensate. (How?) Adjusting mixture to land 1-2-3 idle at 0.96 later today---thank you. . |
1-2-3 target Lambda at warm idle = 0.96
Idle mixture screw now 4.2 turns out - was previously 5 turns out Green = 1-2-3 Blue = 4-5-6 Red dot-dash = 1.0 Lambda Blue dot-dash = 0.96 target 210 temp at dash gauge http://forums.pelicanparts.com/uploa...1734388009.jpg Sides "balance" under load. See posts #65 and 67. Notes: ‘85 3.2 in ‘80 911 Engine rebuilt w/all new ignition parts Mod - SSIs with 2-in-1-out Dansk muffler Mod - 964 Webcams 40i/40e grind Timing = 1.45 overlap Bosch 0280150158 injectors - original to engine - recently serviced by Idaho Bill - all flow 260cc ECU fuel adjustment screw = position 0 Iridium spark plugs Premium fuel ECU recently tested - no faults No vacuum leaks according to oil cap Compression checked = even Tight intake & exhaust nuts Engine ground to chassis = clean & tight O2 gear: Innovate LC-2 dual wideband - cross swapped controllers to proof them 12v regulator + noise filter - 1 each per controller (system = 2 controllers) Calibrated per Innovate specs Bosch 4.9 O2 sensors - also cross swapped to proof accuracy Data logging = LogWorks Single issue I experienced with Innovate = connectors between controllers and sensor extension cables required adjustment (magnifying glass needed.) I have 3 controllers each (3rd is spare) and every male connector would not fully mate female side (that being in the extension cable) without adjustment. Some male pins needed their noses compressed. If sensor drops off, is advisable to check these connectors for a tight male-female fit at every pin. Electrical - YouTube vid called out LC-2 having issues prior to including voltage regulator. Is reason for those being installed here. While at it, noise filters were also included. V-regulators are just after battery. Noise filters are just before controllers. Have relays switching both "clean" circuits running from the battery to the controllers. Each controller has a dedicated circuit. Not saying this is right way to do it. Is way I did it. . |
Yes correct! I first find the peak lift on the dial gauge and then continue around 2 complete crank turn and look for 0.050" before the peak and then again 0.050" after peak. The center between those 2 spots is you peak lift point.
http://forums.pelicanparts.com/uploa...1734716567.jpg
http://forums.pelicanparts.com/uploa...1734716567.jpg City mpg test result after parking brake rebuild - Same station. Same pump. Same fill technique. 12 mpg. ? . |
If your picture is correct your mileage looks to be in km/m...do the conversion and your getting 7 mpg....hard to imagine that.
http://forums.pelicanparts.com/uploa...1734720549.jpg |
And... odo's are correct according to state posted mile markers. Checked both of them a few times with same result.
Grasping for straws.....
A Fuel Leak that somehow only happens while driving and does not cause your car to burst into flame? Speedometer calibration issue? <--- apparently not an issue per the above post Really bad wheel bearings? Given that your mixture is good it seems unlikely to be the engine itself |
At the risk of sounding obtuse, has the O2 sensor been calibrated? Do you know that the data you’re receiving is accurate and not off?
Are you actually experiencing low MPG when driving; are you filling up more often? Sent from my iPhone using Tapatalk |
| All times are GMT -8. The time now is 11:28 AM. |
