76 911s Hotrod First Drive PHX to SEA
Hello Pelicans,
After a few close calls over the decades I've finally taken the plunge and picked up a 1976 Sahara Beige 911s w 3.0sc motor. The car is showing 280000 miles but has seen a fair amount of maintenance over the years. It was offered up on Pcar market in early December and the plan was to drive it home (Seattle) from Phoenix. Life being what it is it took a few weeks before it was time to throw caution to the wind and take a look at what I had purchased. Given the documented service history it seemed like driving a 49 year old car 1500 miles over three days might be possible. Once the holiday festivities had run their course I was given a pass to make the drive. Jan 2nd I took the early flight to PHX and first "met" the car Other than a few things working their way loose the car made it! The most stressful bit was a quick onset of a right front vibration while keeping up with SLC traffic at 80+ mph! By the time I rolled into Seattle I really felt at one with the car. Looking forward to ticking off the items on the todo list and continuing this chapter of the car's history.
Thank you to this amazingly knowledgeable and supportive group of Porsche enthusiast. This forum was a big influence in taking on Porsche ownership.
I also want to send a huge Thank You to Bob in SLC at Concourse Auto (801) 313-9100. I called him in a bit of a panic with the front wheel vibration issue and he dropped everything on a Friday afternoon to get my car up on a lift and diagnose and adjust my loose front right wheel bearing. He was extremely knowledgeable and personable. I don't know what I would have done if I hadn't came upon his name in a separate Pelican thread. Thank you Bob!
Let the maintenance begin!
Roger
own
Old 01-04-2025, 08:48 PM
PCA Member since 1988
Congrats on doin' the "fly'n'drive"! That's the adventure.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-05-2025, 12:15 AM
Nothing better than driving a car back across a state line (or a few!). The anxiety about it making the trip is part of the adventure ;-)
Great looking car: Sahara Beige over Tan (?) is beautiful.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings)
Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/
Old 01-05-2025, 05:33 AM
Nice looking car, I see you have YoM plates.
Ralph W
Instagram @ ralphwlll
1990 C2 Cab
2006 Nissan Frontier
1986 F250
Old 01-06-2025, 09:29 AM
Still here
pmax's Avatar
Nice.
Let's see pics of the bug kill !
Old 01-06-2025, 06:35 PM
Yeah, I do love to fly'n'drive. Last time was picking up an e46 M3 from the bay area. That was fun.
State count = 5 Arizona, Utah, Idaho, Oregon, Washington. The roads in northern AZ beat me up with the stiff suspension. Might have to step the T bars size down 1mm front and rear (to 20/26)
I think the interior color is "cork", but not 100% sure.
Yeah, found plates online and had to. Nice that Washington has that program.
Originally Posted by pmax View Post
Nice.
The last day of drive was through fog, rain,and snow so bugs were washed/blown off. I'll need to wait until summer before the car can collect some serious bugs.
Started having a hot start issue that is looking like a failed fuel accumulator. Also need to track down an exhaust leak. Just waiting for the thin walled 13mm socket to arrive as the car has SSI heat exchangers.
Old 01-06-2025, 08:32 PM
dailydriven911's Avatar
Congratulations!
77’ 911S
Old 01-07-2025, 01:28 AM
Kind of Blue
MrBonus's Avatar
Congrats on the ride home! I hope you have many frustration-free miles.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 01-07-2025, 06:44 AM
Mr. Merk's Avatar
Awesome. You did it right. I always recommend driving the car home and bonding with it.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 01-07-2025, 09:03 AM
Congratulations! Looks like a terrific trip. I love fly and drives. I've done them in my 911, my Saab SPG, and my BMW E12. Each trip better than the last.
'80 SC Targa
Avondale, Chicago, IL
Old 01-07-2025, 10:53 AM
Yes!! What a great adventure. The fly'n'drive is a big move, congratulations!
Old 01-07-2025, 01:30 PM
Originally Posted by dailydriven911 View Post
Congratulations!
Thank you. May the "honeymoon" stage of classic car stewardship continue!
Yeah, the car has exceeded expectations (so far).
Some very good memories. Felt surreal at times.
I think this might be my 5th or 6th Fly and drive/ride. A couple of Syncro Vanagons, a couple of Ducati 900SS/SPs, and a couple other cars.
This choice has worked out very well. Still early days though. May the good times continue to out number the others.
Exhaust leak identified and remedied!
Next challenge is firguring out what is going on here. Found some heavy build up on outside wall of the oil tank. Heavy build up around the oil level sender. ?? Bad gasket? The sender wires were incased in oil/dirt paste. Any insight from a more seasoned wrench?
Let the adventure continue.
Old 01-07-2025, 10:03 PM
Ticking off some items from the to do List
The weekend arrived with me eager to do some wrenching on the 911.
It's colder than normal (30F) today. Was that a factor in the fuel pump not firing up? Had the "pleasure" of removing the panel and giving the pump a couple of taps in order to deliver fuel to back of the car. Guess another item to add to the list.
Next item on the list was to inspect vacuum lines for cracks or being disconnected. The car has a low rpm stumble that clears out once above 2.5k It will also backfire in the exhaust at low rpms with a steady partial throttle. Couldn't find any obvious vacuum leaks but did find the intake boots (connecting to the air box) a little loose. Tightening those seemed to help things a little. I have picked up a fuel pressure gauge setup but ran out of time to base line the system pressure and control pressure.
Cleaned up the contacts on the cap and rotor.
Also won the battle with the right rear tail light assembly. Last weekend I attempted to pull the assembly in order to inspect the wiring and was stuck with a spinning outside captured nut. Doh! I could see it from the wheel well but didn't have the right tool to hold it in place. The 11" needle nose set arrived during the week enabled the removal of the light. Slightly longer pliers would have been better but was able to make the 11" versoin work. Took the opportunity to replace the dried out lens gasket. Very happy to have a correctly fastened tail light.
Lastly, swapped out my old puffy sun visors for brand spanking new units. There is something about puffy sun visors that rubs me the wrong way.
All in all a pretty productive day. Just need to keep chipping away at the list.
Roger
Old 01-18-2025, 09:20 PM
