cmpski's Avatar
Aluminum bodywork
For those who have not seen this project, I thought I'd post some pictures even though this is a 2.7 liter 69 912 POLO car.
Things are starting to take shape under the hood of the 69 912 POLO car.
There is a 200F degree BAT thermostat in the middle of the crossover oil lines. The SC thermostat at the passenger rear wheel well opens at 180 degrees. The oil will go forward from there then through the front passenger cooler. The BAT thermostat will send the oil back to the rear tell the oil temp gets to 200 degrees. At that point the BAT thermostat will open and route the oil to the drivers side cooler. If this works as well as I hope, I’ll do the same to my car. My car the oil sits at 180 to 190 degrees on a hot day which is fine. 200 to 215 would be better. But on a cool or cold day it sits at maybe 140 to 160. Too cool. At those temps the heater struggles to warm the inside of the car, and the water vapors in the oil can't boil out even with lower boiling points at higher elevations here in Colorado.
As the hood is of super light weight aluminum, (thinner than 16 gauge) it needs more support when lifted to fuel up. So we supper sized a 914 race car hood support. The support snaps in at the back end of the hood when the hood is down. It snaps in on the backside of the strut bar when the hood is up. The support piece is connected to the middle of the hood front to back to not over stress the hood when it’s opened.
This has been a fun project.
These 3 threads have over 400,000 page views on the Early 911S Registry, over 100,000 here on the 912 threads. Probably 3/4's of a million page views if you add in the 912bbs.org and my site. I love tinkering on these cars.
https://www.early911sregistry.org/forums/showthread.php?137757-1969-912-reSee-Works-Build&p=1190357#post1190357
https://www.early911sregistry.org/forums/showthread.php?174711-Making-a-complete-Aluminum-engine-lid-from-scratch
https://www.early911sregistry.org/forums/showthread.php?69778-POLO-4-cylinder-911-engine-and-1967-912-almost-done/page47
1959 Auratium Green 356A Super w/ Rudge wheels
1970 Irish Green 914-6 w/2.2S
Current -1967 Bahama Yellow 912 POLO 2cam4 #1
Handles like a 912 and goes like a 911
www.reSeeWorks.com
Old 11-12-2024, 08:22 AM
