Heater Backdate Question?
Hey guys,
I’ve got the left side heater backdate duct on my motor, but not the right hand side one because I need that space for my A/C compressor. Is the airflow from the left side backdate duct enough to push air through both heater exchanger inlet ports, so I can get enough heat into the cabin? I presume the blower motors inside the cabin will draw enough warm air into the cabin? Advice appreciated. |
I have the one duct only, without the blower motors, and it works fine. Sadly though, the car resides in SoCal and not much heat is needed...ever.
You can buy a new right side heat duct from Porsche that clears the AC bracket/compressor. It comes in 3 pieces.
my backdated unit gets plenty hot using one side - i rarely open the passenger side. being in motion is the key - i wouldn't want to commute in stop and go traffic, if it was truly cold out. ..... and? defrosting could become an issue, RHS. yes?
Agreed on this point. I have backdated mine and have both ducts on with AC, however I often just use the driver side lever and it is plenty! |
Cool. Thanks for confirming guys.
I think I’ll connect up the engine duct to the right hand side heat exchanger so the driver gets all the heat. Oh, this is a RHD vehicle as I’m in Melbourne, Australia 👍🏼 Doesn’t get TOO cold here, and I don’t plan to drive the car much at all in Winter anyway. It’s just a “nice to have” in the event it’s a little chilly when out and about. Curious, is there a part number for the 3 piece right side duct that clears the A/C?! |
Now I just need a 2.5” to 3.0” aluminium transition for the 3.0” heater ducting to my right heat exchanger (993TT heat exchangers). |
check my post here, I modified the existing block off plate for about 20$ and it clears the AC bracket:
https://forums.pelicanparts.com/porsche-911-technical-forum/1169400-1983-sc-heat-backdate.html#post12356155 |
#5, 6 & 7 plus hardware
https://cfc98bf154776a005971-0d22d64...com/105-05.gif http://www.auto atlanta.com/porsche-parts/hardparts.php?dir=911-78-83§ion=105-05 |
| All times are GMT -8. The time now is 01:41 AM. |
