I'm with Matt on this one. If I see a crack or cracks in the ring or pinion, its getting a new set. And as Matt said, replacing the ring and pinion will likely double (or more) the cost of the overhaul.
As for test driving, pay really close attention to when the noise happens. Accelerate through the gears at various engine speeds. Is it noisy in one particular gear? Does it quiet down in one particular gear? Does the noise remain constant but get louder as the car goes faster? Is the noise a steady drone, or is it a rhythmic noise? Does it sound more wheel speed related, or faster, like engine speed related? Test drive again and get back to us. |
The humming happens in all gears. After the car gets up to speed, if you “goose” the gas pedal, the sound appears on acceleration only, not when I take my foot off the gas. It doesn’t appear to increase with the speed of the car. Looking back, like I said, I made the wrong decision not giving the OK to replace the ring and pinion, but the car was never making this sound. And thank you Pelicans for all your help and knowledge, I really appreciate it. Mark |
Might just be your throw out bearing based on what you are describing. Doesn’t sound like the ring and pinion.
Transmission noise
That would be a gift if that is what it is. I’m able to pull the motor and transmission myself. Is there a way to check the TO bearing once I have it apart? Thanks, Mark |
