Make Bruins Great Again
Problem with Wheel
A friend of mine has a `95 C4 with factory Speedline Turbo Cup wheels. They are 2 (3?) piece wheels and one of them has a leak where the lip is bolted to the wheel. He says that he can buy a new one for about $1340. He's tried Wheel Enhancement and Tire Rack and neither one knows who might fix them.
Is there anyone out there than knows who can fix these?
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
You can't just run a bead of silicone there? Sorry, don't know the wheel, so if the tire bead or something needs to be there, I understand why you can't. Most bolt together wheels need silicone.
He says he ran a very small bead of silicone on the wheel and it slowed it down some but still leaks. How much silicone does it need?
call FVD they sale bbs and speedline 3p wheels probably you can get the new part from them, bbs 3p wheels use some kind of seal there.
X/A |
Never heard of FVD. Do you have a number?
is the leak where the wheel bolts together, if so did he just have tire work done its very common to break the seal if the tire is removed, the tire tech will usualy stick the tire tool all the way in damaging the silicine seal, you can probably find someone to take it apart re seal it, if you are talking about a crack, buy a new wheel or send it to speedline and have the barrel replaced, Kevin
X/A |
Kevin-the problem is he can't find someone that will fix the seal and $1340 is a bit much for a new wheel.
Yellowbird-thanks for the link.
