Oil leak
89 911 Looks like my oil cooler is leaking. Could be the seals or cooler itself. Where is the sensor located? If it is near this could be the leak. I cleaned it off and will check it next week. Can the cooler be easily removed from the bottom? What about the oil pressure sensor?
A pic would help.
Gilles RoW 88 Carrera coupé |
PCA Member since 1988
Yes, a pic would help, but only a little. You will have to clean and track where the leak is coming from. There's lots of threads and discussion about leaks around or near the oil cooler (as well as other parts of the engine). Start there and then narrow your problem down to more specific questions.
Have you done any work in that area recently, or did this just start leaking de novo?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
actually i prefer when there is an oil leak not to clean at all!! The leaves a trail from which i usually find the problem;-)
Ivan
1985 911 with original 501 645 miles...807 319 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
