Searching for bad ground ...direct me where to look!
Anyone have a picture or able to direct me exactly to ground wires I believe are in the photo that are affecting my mirror direction. under the dash or in the frunck, if so where?
I get panning only no tilt...got to be bad ground.
Which car? Is that a 944?
if you go any movement on the mirror ..it is not a bad ground more likely connections.Is it on both mirrors?i`d start with the mirror switch
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
it’s an 85 911
while testing the pass side, i had the green wire on test light to see if it was ground, while it was grounded the left side mirror worked perfectly… it tilted. disconnected the test light from the green and the driver side once again only panned, no matter which way I pushed the switch. seems the ground is goin ln the one direction, from the pass to the driver side. not getting anything in the test light from one of the 2 brown grounds on the switch. crazy stuff. must not be grounded somewhere and the tilts won’t work, but both pan only. I know motors are good, had them on another car to test.. and switch works as well. know that after the driver side worked with green wire on pass side was tested. |
is there more story to this? like you had the wiring apart and e.t.c.??
If yes there is a little trick to the wires on left connector.If i weigly remember there must be 2 different wires connected together on left side....do so wiring dia search ivan
got all the diagrams. but just dont see it. got to be a ground. like to know where those are located
oh well, can i see see your plug (2 white with pins)connection beside the left mirror--you would have to take it apart to show.Also you did not say --have you worked on the mirrors or it happen suddenly??
Ivan
I happened slowly...1 then, later the other
Checked the motors, door switch, directional switch (switches left mirror or right) Diode were cahged due to conncting wrong wires together...again they work fine on another car. See my above post about testing green wire on pass side. Not getting ground on one of the brown wires on pass side. I will dig out the photos of each inside mirror wiring. |
I think the ground, brown wire, connects in the frunk by the fender and door post.
I had to repair my wires in drivers door by hinge side they wore thru just where they entered the door.
the mirror has a motor that connects via a plastic bracket to plate that holds the mirror. So if it moves up down but not side to side, that could be a broken bracket. My DS mirror was like this when I bought the car, it moved up and down but not side to side. I found a replacement mirror drive on eBay and that resolved the issue.
The wiring diagram seems to indicate that pins 4 & 5 are connected together and also run to ground. |
Popsracer
I know EVERYTHING there is to know about the mirror assembly.. at one time i figured out the diodes were burnt out, took the mirror apart and changed them. As you can read in my original post, the mirrors work PERFECTLY… on a friends car, my question is where are the ground points? By the way they are behaving, it MUST be a ground wire. do appreciate the help! |
Ground point MP III for the lefts and MP V for the right.
