-   -   Central Locking Control Module Relay needs cleaning (http://forums.pelicanparts.com/porsche-911-technical-forum/1171169-central-locking-control-module-relay-needs-cleaning.html)
jgurnari 12-06-2024 01:42 PM
this is a, believe it or not!, working Central Locking Control Module Relay and is in need of cleaning
How can I clean it safely?
http://forums.pelicanparts.com/uploa...1733521244.jpg
John W. 12-06-2024 04:00 PM
I would use electrical contact cleaner. Put some on a swab and gently wipe. Don’t use Qtips because cotton fibers will get all over it. Amazon sells foam swabs.
wazzz 12-07-2024 04:01 AM
Isopropyl alcool. Gently wipe with a soft brush. Let it dry by itself. But if it's working why do you want to clean it? Old analog electronic circuits such as this one are bullet proof and not very sensitive to dirt, dust or whatever.
jgurnari 12-07-2024 07:13 AM
not being use
It’s sitting in a closet not being used, thought it might continue to corrode if not cleaned up. no? i cant believe, by the looks of it, that it works
911obgyn 12-07-2024 08:44 AM
DeOxit will put a bit of protection on it and help clean it.
mysocal911 12-07-2024 12:35 PM
Yes, corrosion (moisture or actual water) occurred - it's not "dirty".
Lammers 12-07-2024 01:06 PM
Mine works and so does the center button!
If you ground pin #1 or #7, it will close or open. I bought a $10 remote key from ebay and wired it up according by soldering a tiny wire to those pins etc. Keyless open/close, very convenient and totally reversible.
