-   -   Distributor question (http://forums.pelicanparts.com/porsche-911-technical-forum/117120-distributor-question.html)
yeuporsch 07-01-2003 11:37 AM
How can I tell the difference between a Bosch and a Marelli distributor without pulling it out of the engine? My car is a 72T. The number on the distributor is 030.
John
David E. Clark 07-01-2003 12:06 PM
The Marelli has a much "taller" cap. Look at the attached pictures of Marelli distributors and compare them to yours.
http://forums.pelicanparts.com/uploa...i_dist_cap.jpg
http://forums.pelicanparts.com/uploa..._dist_cap1.jpg
Hope this helps SmileWavy
yeuporsch 07-01-2003 01:07 PM
Yup, mine is a Bosch then. Now I can order the correct Ignitor for it. Tired of points. Thanks for everything.
John
Tim Walsh 07-01-2003 01:16 PM
I've got an extra marelli dizzy if someone needs it. Even has the cap, rotor and points :D
David,
Are those your cap and rotor?
David E. Clark 07-01-2003 01:51 PM
No, they are from Ebay. I saw them today looking around Ebay and when I saw this post, I figured a picture was worth a thousand words!
