Where does this go - Defrost light found under passenger seat
While I was working on replacing the fuel lines in the tunnel on my 1984 Targa, I found this under the passenger seat.
It seems to be a light for the defrost levers. Where does it mount in the car? Can anyone show me a picture of it in place?
Old 12-07-2024, 04:30 PM
That's fond- just deglaze
Hi ErrorMargin- here's a summary post and image. I suspect you might have fresh center tunnel carpet, or a PO forgot to place the receptacle back (over the carpet) after previous work was performed. FYI- The image is from a BAT '84 Targa with 30K miles.
https://forums.pelicanparts.com/porsche-911-technical-forum/1045352-what-small-light-used.html#post10660827
Cooking on a Porsche 911- The herbal butter made the difference.
https://www.youtube.com/watch?v=FvXBR50rH9E
Missed Approach
Petra- 1986 Coupe
Old 12-07-2024, 06:16 PM
Originally Posted by Missed Approach View Post
Hi ErrorMargin- here's a summary post and image...
Thanks!!
Old 12-07-2024, 09:42 PM
famoroso's Avatar
That unit consists of a base, with a bulb, and the cover. It's illuminated. If they deleted it, hopefully they taped off / used heat shrink tubing on the body side harness electrical connector (wire is black with blue stripe) so it doesn't short to ground.
If you're ever working in that area (like during center console removal), you may want to inspect for that.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 12-08-2024, 05:44 AM
Originally Posted by famoroso View Post
That unit consists of a base, with a bulb, and the cover. It's illuminated...
I see that our host has it in stock: https://www.pelicanparts.com/More_Info/91463210700.htm
Any idea what screws are supposed to be used to mount it to the floor? Or what bulb it takes?
Old 12-09-2024, 09:58 AM
I tested the wire on mine and verified that it does get power when the lights are on, so I should be able to reinstall this no problem.
The bulb in mine is fried, so I need another one, and I need the mounting screws. Can anyone help me on these two?
Old 12-09-2024, 03:02 PM
Hi ErrorMargin- you'll need two TAP SCREW 2.9X13 Part# GN0139541 and the bulb is #90063113290
Missed Approach
Petra- 1986 Coupe
Old 12-09-2024, 04:37 PM
here's an image with the tap screws and bulb...
Missed Approach
Petra- 1986 Coupe
Old 12-09-2024, 04:41 PM
