-   -   ITB Install - Linkage Question (http://forums.pelicanparts.com/porsche-911-technical-forum/1171246-itb-install-linkage-question.html)
KMoore68 12-08-2024 03:45 PM
Hi,
I running into a problem connecting my Closed Course Motorsports ITBs linkage to my existing linkage.
Here is a picture:
http://forums.pelicanparts.com/uploa...1733701370.jpg
As you can see the old vertical linkage has a push-on connection. The replacement uses a nut and bolt inserted into a ball joint. I can't connect the new linkage and need to replace the vertical part but i'm not sure where to find it.
Any ideas?
KMoore68 12-08-2024 08:33 PM
Big help from Al Kosmal, he pointed me to a solution!
Thanks Al
