Alan L's Avatar
FA query
If you get a fail result on a FA residual pressure test, can you have a good FA and a leaking pump check valve?
How do you distinguish between the two?
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 12-10-2024, 09:22 AM
E Sully's Avatar
A residual pressure test does not show which component is leaking. Yes the FA can still be ok, you would need to remove it to check individually. The residual pressure test can fail due to a leaking WUR, fuel pump check valve, FA, or fuel distributor pressure regulator.
Ed
1973.5 T
Old 12-10-2024, 12:36 PM
Alan L's Avatar
Thanks Ed - that is what I was suspecting. Just that you see a failed Rest Pressure test and the first result seems to be to throw a new FA at it.
Have a mate with an SC hot start issue. Just piecing together where we go with it.
So the answer would be to remove the FA and bench test - if the result is suspicious.
Regards
Alan
Old 12-10-2024, 02:37 PM
FA Test In Situ…….
Allan,
You can test and evaluate a FA in situ. Disconnect the bottom port of your FA and test run the FP for several seconds (no more than 5 sec.). A good one will not leak from the bottom port. If it leaks fuel during the test, it failed the test. Place something to collect the fuel from the disconnected bottom port fuel line and under the FA during the test.
Or removed the FA from motor and do a pressure test on the bench. There are other known sources of residual pressure loss culprits for SC’s.
Tony
Old 12-10-2024, 07:25 PM
Alan L's Avatar
Good tip Tony - thanks.
Alan
Old 12-10-2024, 09:45 PM
Schulisco's Avatar
I always recommend a bench test of the FA with pressurized air!
The problem is that the FA must not only be tight for fuel, it's also urgently required to move free and smoothly! Many FA are tight for the fuel, but their plunger cannot move free and smoothly any more and gets partially stuck or hesitates the sweeping fuel pressure changes (due to wear and corrosion). This heavily affects the mixture and running culture of the engine!
How can you test it, see my postings there:
https://forums.pelicanparts.com/porsche-911-technical-forum/1119829-accumulator-pump-check-valve.html
After replacing the FA check (and adjustment if out of spec) of the mixture is mandatory!
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 12-11-2024, 06:29 AM
Originally Posted by E Sully View Post
...Yes the FA can still be ok... a leaking WUR,....
English is NOT my first language but I think I can make myself understandable and I understand 80% of English, French and German text. I've a friend who helps me with the other 20% (Google).
My biggest problem is the abbreviations!
There are some threads with dozens of them. In this thread there are only a couple:
FA ?? WUR ??
Help me...
Old 12-11-2024, 08:20 AM
Schulisco's Avatar
@avenbugt
FA = Fuel accumulator
WUR = Warm Up Regelulator
All the CIS components are briefly described here:
https://cis911primer.com/pages/comp_page.html
Basically any CIS component has it's own abbreviation, assembled from their initial letters, like the CSV = Cold Start Valve, AAR = Auxiliary Air Valve, etc.
If you're not so familiar with CIS I heavily recommend to watch the CIS related videos from Curts (KlassikATS.com) marvellous playlist about the 2.7l 911, the CIS components are pretty much the same on the 3,0l SCs except Lambda controlled US SC from 1980-83 as they add an electronic lambda control on top of the all mechanic CIS:
https://www.youtube.com/playlist?list=PLkWFofpgz2OgF9FdliKnlzuY0pygqRkMj
Also literature like the mentioned CIS primer...
Further reading:
https://www.benzworld.org/attachments/cfe06613-d83a-4461-9d69-260cb7ab4da4_bosch_k-jetronic-pdf.2840103/
https://www.benzworld.org/attachments/k-jetronic-workshop-manual-pdf.2840104/
Add: Here's a very basic introduction made by VW / Audi in their self study programme, unfortunately in German and not English:
http://www.volkspage.net/technik/ssp/ssp/SSP_44.PDF
Thomas
Old 12-11-2024, 09:15 AM
Schulisco
Thank you for the useful links!
Vielen dank.
Old 12-11-2024, 10:14 AM
